Continental Tire Problems
Old Sep 21, 2007 | 11:38 AM
Arcrist's Avatar
Default Continental Tire Problems
Just wondering if anyone else is having problems with heavy tires (aka out of round).
I've gone through two tires back to back that were faulty. I'm getting replacements but they're the same kind, I'm stuck with what discount tires and the chrysler dealership warranties. Conti's are now made in Czech Republic instead of Germany.
Old Sep 21, 2007 | 01:11 PM
spensley's Avatar
Default Re: Continental Tire Problems
Are they out of round when you get them?
Front or rear?
LH or RH side?
Wearing evenly?
etc. etc.
Old Sep 21, 2007 | 01:32 PM
ColoradoXFire's Avatar
I just replaced Conti All Seasons with the same about 1K miles back. No problems so far (fingers crossed, knocking on wood)...
Old Sep 21, 2007 | 02:19 PM
kjmurphy's Avatar
Archrist,
I have the Continentals as well and both of my rear tires are out of round with cupping and flat-spotting. Chrysler has not gotten back with me on replacement.
Kevin
Old Sep 21, 2007 | 02:49 PM
SilverFox's Avatar
Thumbs down Re: Continental Tire Problems
Have/Had Contis, on both of my Roadsters & No issues so far! (Knock on Wood!)
SF
Old Sep 21, 2007 | 07:31 PM
palexfire's Avatar
i have conti no problem ... it could be you might need an alignment...
Old Sep 21, 2007 | 08:03 PM
MAKIII's Avatar
I bought my Crossfire over the Internet and the phone, car was everything the dealer said it was - EXCEPT the tires - Conti touring - both rears had and 1" to 2" crack in the sidewalls and the fronts had them but smaller. Didn't notice till I got the car home - 300 miles, needless to say the tires were trashed quick - got Goodyear FS1's. My '97 Audi cab came with Conti's, they were awful in the rain - went with Firestone's - softer rubber compound quieter and held corners well.
Old Sep 21, 2007 | 09:39 PM
intenseblu's Avatar
conti extreme contacts here ... no problems ...
how long have you been driving on them ? perhaps having them balanced on a road-force balancer by properly trained tech would solve your out of balance issue as that machine takes into account the balance of the tire and wheel separately and allows the tech to rotate the tire on the wheel until they are as perfectly balanced as possible without the use of weights ... then the final run is for adding weights ... a lazy tech will never do this however as rotation of the tire on the wheel is a physical chore they do not enjoy.
just mentioning in case ... not necessarily cause that is the case.
Old Sep 21, 2007 | 09:46 PM
CrossfireLTD's Avatar
Cool Re: Continental Tire Problems
Conti extreme contacts here also...no problems.
Old Sep 22, 2007 | 01:11 AM
PJA's Avatar
PJA
I believe your problem is with Conti, not Chrysler. Good luck.
Pete
Old Sep 22, 2007 | 01:16 AM
Mediacritic's Avatar
Conti all seasons here. No problems.
Old Sep 22, 2007 | 06:12 AM
Arcrist's Avatar
I had Discount tires road-force my tires and they were bad, chrysler said there was nothing wrong with them. But I have actual data from DT showing they're faulty. Once these fronts are worn, im never going back to continental. I have some flame tread G-forces in the back that work great, so maybe I'll match the fronts in a few months.
Old Sep 22, 2007 | 09:53 AM
Captnmrgn23's Avatar
contis and no probs!
Old Sep 22, 2007 | 10:33 AM
SRT-6 Steve's Avatar
Conti's are noted for this problem as well as higher road noise. Some models are worse than others. I hated my original equipment Conti's. I purchased Yoko's and couldn't be happier. Softer ride and much quieter. No flat spots even after sitting for days.
Steve
Old Sep 24, 2007 | 02:54 AM
Ausfire's Avatar
Conti Sport Contact 2's.
Front right wore down to 2.3mm tread at 30,000km. It was even wear across the tread.
Front left still had 6.5mm tread of the 8mm tread depth on a new tyre. For the first time ever I replaced only the one tyre not a pair.
Rear tyres still have average 5mm tread remaining.
I can't complain, but I don't know why one tyre wore more than the others.
PS. Contis are "Engineered in Germany" but have manufacturing plants in a number of countries.
PNA
Nov 12, 2020 04:44 PM
tom2112
Oct 26, 2015 08:18 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
tom2112
Jul 12, 2015 04:41 PM
tom2112
Jul 8, 2015 08:13 PM
