leaky?!
Old Jan 28, 2008 | 07:09 AM
azcrossfire's Avatar
Default leaky?!
i have a white 04 and the other day it rained and i noticed an area on my headliner that was soaked by the rear hatch driver side...has anyone else ran into this problem...its a coupe and everything is straight and lines up perfectly...anyone have any suggestions
Old Jan 28, 2008 | 01:30 PM
crossfirefun's Avatar
Default Re: leaky?!
Does the weatherstrip look intact? Try putting a peice of paper between the rubber and the hatch. With the hatch closed you should not be able to pull out the paper. Maybe the stops are adjusted to tight and the rubber is not touching.
Old Jan 28, 2008 | 02:35 PM
No Warning Shot's Avatar
Default Re: leaky?!
I'm with ya... I have a big water spot in the same spot on the passenger side.
Old Jan 29, 2008 | 07:38 PM
Default Re: leaky?!
i think i got it i just looked at the rubber guard and the water was from the top corner on the driver side...just squeezed the piece together and put ir back in place...was afraid for a min. going to recover the headliner black suede cause the old material is ruined.
MK2005
Nov 12, 2015 11:11 AM
josh armstrong
Sep 22, 2015 01:19 PM
goodgenes79
Oct 18, 2014 09:06 AM
amx1397
Apr 7, 2010 11:55 AM
