Annoying wine
Old May 14, 2008 | 05:17 AM
Arc's Avatar
Arc
Default Annoying whine
When I turn my ac or heat for that matter on in my 05 coupe I hear a whine of some sort. It sounds like something is in the fan but I cant imagine what could have got in there it only has 5,000 miles on it I got it about 2 weeks ago used. Has any one experienced this problem? It is sill under warranty so I am not that worried about just curious to the cause of the sound.
Old May 14, 2008 | 05:42 AM
maxcichon's Avatar
Default Re: Annoying wine
I prefer a dry red, but it depends on the entre. I find wine only annoys me if you mix the menu.
Old May 14, 2008 | 05:53 AM
Arc's Avatar
Arc
lol sry typed it fast. I am at work trying not to get caught goofing off. wine = good
whine in ac = bad
Old May 14, 2008 | 06:12 AM
xfire2005's Avatar
It totally depends on the vintage as some years cause a harmonic distortion upon stimulation via ignition.
Old May 14, 2008 | 08:08 AM
maxcichon's Avatar
whine in ac = bad
I'm sorry. I, once again, couldn't help myself!
As to the problem, I've seen a few folks on here find leaves and other detritus in the fan housing. Do a search.
Hopefully it's not a mouse!
Old May 14, 2008 | 09:48 AM
Arc's Avatar
Arc
lol it is fine, where is the fan located so i can check it. sry my xfire did not come with an owners manual.
Old May 14, 2008 | 09:55 AM
chuck65's Avatar
I have the same thing in my roadster. It's pretty quiet and I consider it normal. Mine winds down in sound after I turn the key off. If it gets any louder I'll look into it.
Old May 14, 2008 | 10:28 AM
xfire2005's Avatar
I believe that the fan location is in back of the cabin air filter which is below your glove compartment.
(Sorry about the wine joking, whining sounds in your car can be annoying)
Old May 14, 2008 | 10:48 AM
Arc's Avatar
Arc
ok thanks when i get off work ill check behind the filter... the filter still should be good how often do you guys normally change yours?
Thanks
Chris
Old May 14, 2008 | 11:05 AM
Idaho's Avatar
Arc, pull your filter and check the duct work for leaves and tree seeds. My car is garaged and only gets driven six months of the year and when I changed my filter this year there was all kinds of leaves and weed seed in the filter. According to the service manual the fan is just behind the filter and that you need to remove the lower instrument panel cover and you should see a blower motor cover door.
Old May 14, 2008 | 11:22 AM
Arc's Avatar
Arc
thank Idaho will do it first thing when i get home if the proplem continues ill take it to a dealership and hope warrenty covers the proplem. If they tell me it is leafs in the fan then i will clean it my self. Thanks again for all the help guys
Thanks
Chris
Old May 14, 2008 | 03:09 PM
fiberboats's Avatar
Default Re: Annoying whine
There might be crazy canuck wine 'ng under dash lookin for cabin filter heheh like i did
joking
Old May 14, 2008 | 04:15 PM
robby363's Avatar
You can download a owners manual here plus some other files that you might find helpful. https://www.crossfireforum.org/forum...ad.php?t=13875
Old May 14, 2008 | 04:19 PM
70GT6's Avatar
The bottom of the fan disconnects the same way the filter does. Slide the levers over and you can clean out the fan housing.
As for filters the best I saw on the forum is if you smell "pickles" it is time to change it.
Rob M
25
Nov 5, 2015 05:23 AM
spoiler
Sep 2, 2015 08:56 PM
PNA
Car Shows
Aug 3, 2015 08:22 AM
PNA
Crossfire Events and Meets
Jul 13, 2015 11:40 AM
mightyjlr
Apr 29, 2006 02:51 AM
