Power Window Problem
Old May 25, 2008 | 04:03 AM
tlppsp's Avatar
Default Power Window Problem
When using the auto down function on the power windows, they sometimes go down just like they should and other times they start down and stop part way. If you push the power window button again they start down and stop and this continues untill you manually put the windows down all the way. I can't find any common reason for the next occurance, one time they go down just fine and whenever they act up. Help keep me away from the dealership service dept., please tell me how to fix them.
Old May 25, 2008 | 12:14 PM
tlppsp's Avatar
Default Re: Power Window Problem
Still no help solving this one, I know we have some electronic experts on this forum, help!
Old May 26, 2008 | 05:27 AM
Iamfink2's Avatar
Is it just the drivers side or passenger side as well? If its just the drivers side its probably just the switch.
Old May 26, 2008 | 05:34 AM
tlppsp's Avatar
It's both windows. I'm starting to think it's in the control module located in the engine compartment.
Old May 26, 2008 | 06:32 AM
CRM's Avatar
CRM
Before ya get too crazy,try re syncing them.
Press and hold the button in the down position until the window reaches the bottom.Continue to hold the switch a few seconds after the window has reached the full open position. Do the same for the closed, close it completely and hold the switch a few seconds once the window is completely closed.
Old May 26, 2008 | 09:00 AM
tlppsp's Avatar
I didn't know you could "re-sync" the windows. I'll try it and let you know if it works this PM. Thanks.
Old May 26, 2008 | 02:39 PM
tlppsp's Avatar
Problem is still there, "re-sync" didn't work.
Old May 26, 2008 | 04:41 PM
CRM's Avatar
CRM
Sorry,sounds like it's time for some pro help.....
Old May 28, 2008 | 02:44 AM
tlppsp's Avatar
Any sugestions from the electronic geeks? Still not working, thanks.
PNA
Nov 12, 2020 04:44 PM
ricardo 53
Jul 21, 2015 07:49 AM
55chevy
Jul 20, 2015 03:08 PM
waldig
Jul 15, 2015 02:05 PM
