Brake wear light
Old Jun 21, 2008 | 05:13 AM
Punkin's Avatar
Default Brake wear light
After 37k miles the brake indicator lit up. As I had Gold Rotex on the shelf, I decided to change them. Well...... for you procrastinators or get to it soon type of drivers, do not wait to long. Reason being, when that indicator comes on, you have VERY little pad left. Don't wait to long cause you'll need to buy new rotors.
Old Jun 21, 2008 | 08:24 AM
Chris L.'s Avatar
Default Re: Brake wear light
37 K, was a lot of that city driving? I had a Beretta GTZ that went way over 100 K miles before I needed new pads....course it blew head gaskets every 30-50 K miles...
Old Jun 21, 2008 | 02:12 PM
Punkin's Avatar
The wife drives it in town here (slow speed and easy). The pads are softer than many but stop great. I am not surprised at the milege. I got over 90K from my Dodge Ram brakes and 100k from the tires but it is what you buy.
Just letting you know that when the light comes on, replace then soon or it will cost you!
Old Jun 29, 2008 | 03:03 PM
donschorr's Avatar
So after you put the Rotex Gold pads without changing the rotors- have you had any squeaks or noticeble uneven grabbing from the brake pads?
Did you turn the rotors?
Thanks
Don
Old Jun 29, 2008 | 07:40 PM
04chryslr's Avatar
there should be no need to turn the rotors after 37k miles
Old Jun 30, 2008 | 06:09 AM
Punkin's Avatar
The wife said it has a sqeek that comes and go. The rotors had a small lip on the outer edge. I usually do not turn the first set of pads unless of course it is really bad. If it's bad you probably have something going on. I'm just a shadetree mech so this is just my feelings. If the sqeek continues after the pads set on the rotor, I'll look deeper into it.
Old Jun 30, 2008 | 08:11 AM
donschorr's Avatar
The reason why I asked, according to other members on the forum- our rotors are only good to about 35-50K miles....... at that point they need to be replaced.
The other reason I wondered if the pad footprint on the Rotex Gold is very similar to the stock pads,, I am considering replacing my front stock pads with the Rotex Gold- my car has about 16K miles and if I don't have to replace the rotors I don't want to.
Thanks
Don
Old Jul 1, 2008 | 06:57 AM
Punkin's Avatar
I find it very hard to believe that any manufacturer would install rotors that were only good for 35-40k miles. Next pad set I will have them turned. If they can't meet spec's, I'll replace them then.
Old Jul 1, 2008 | 09:00 AM
donschorr's Avatar
Punkin,
I agree.... just what I have heard, throw away rotors....
Old Jul 2, 2008 | 07:00 PM
04chryslr's Avatar
thats not correct at all, I have over 50k on mine I just changed the brakes, the rotors look perfect
Old Jul 3, 2008 | 09:44 AM
Goldwing's Avatar
I think it depends on how you drive. I did almost exclusively highway on my Saturn Vue until I gave it to my daughter at 118k, and she finally needed brake pads at 142k. They were able to turn the rotors.
When I picked up my used SRT6, it had a bad shudder when I braked. I thought it was warped rotor(s) from driving them through puddles when hot. Then I drove it in a bad rainstorm and the problem went away almost entirely. I now think it was a stuck caliper that was dragging. Unfortunately, I had already ordered rotors and pads, so I just had my shop replace them. I don't mess with brakes or tires on a vehicle that I often run to 120-150 mph. I think parts were $400 and labor was only $156, and I won't have to mess with them again for a long long time.
Old Jul 3, 2008 | 03:39 PM
04chryslr's Avatar
i'll tell ya what though i'm almost 21 so you can imagine how my driving is LOL and the rotors on my car were perfectly fine.
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
PNA
Jul 27, 2015 12:28 PM
ricardo 53
Jul 21, 2015 07:49 AM
