General Tire - Exclaim UHP (Advice Needed)
Old Jun 25, 2008 | 07:13 AM
Fired UP's Avatar
Default General Tire - Exclaim UHP (Advice Needed)
Hey Guys....
I am going to be replacing my worn Pilots in the near future.
What do you think of these????
Discount Tire
Front: 225/40-18XL 91W BSW @ $112 each
Rear: 255/35R19XL 96Y BSW @ $203 each
Discount Tire offers a $25 discount for buying and making an appointment on line.
In addition, General will send a $50 Visa Card as well.
Does anyone know how high I can go on the front and back.
I want to fill the wheel well a little more and also get a slightly softer ride as my 06 LTD is a daily driver.
I am not so much worried about cornering performance as I don't get on it very often but I do engage the WARP SPEED button from time to time.
Any advice would be appreciated
http://www.discounttire.com/dtcs/fin...014290&ct=null
Old Jun 25, 2008 | 07:23 AM
maxcichon's Avatar
Exclamation Re: General Tire - Exclaim UHP (Advice Needed)
Use this calculator:
http://www.rims-n-tires.com/rt_specs.jsp
It's very easy to do!
Old Jun 25, 2008 | 07:44 AM
Fired UP's Avatar
Default Re: General Tire - Exclaim UHP (Advice Needed)
Thanks Maxcichon....
Do you know the whell dimensions so I can plug them in?
Front=18 X ?? Et??
Rear= 19 X ?? Et??
Old Jun 25, 2008 | 07:52 AM
maxcichon's Avatar
Front=18 X ?? Et??
Rear= 19 X ?? Et??
Front 18X7.5 ET +35
Rear 19X9.5 ET +22
Old Jun 25, 2008 | 08:01 AM
Fired UP's Avatar
Front 18X7.5 ET +35
Rear 19X9.5 ET +22
Thanks for the help Maxcichon......
Do you know what the limits are for height and width???
I dont want to rub.
Old Jun 25, 2008 | 08:44 AM
Fired UP's Avatar
Does anyone know what the limits are for height and width for our tires???
I want to go a little taller Front and Rear but I don't want to rub.
Old Jun 25, 2008 | 10:42 AM
maxcichon's Avatar
On the front, you must be careful to avoid the Upper Balljoint Nut. If you stick your hand in along the top center of the tire you will feel it. Only ~ 1/2" of clearance.
I just installed
Front 235/35X19 ET 35 (Bigger Rims with no issues)
Rear 275/30X20 ET 30 (Bigger rims with no issues).
Use these as "Original" sizes and do not exceed.
Should work.
Old Jun 25, 2008 | 10:50 AM
Fired UP's Avatar
I just installed
Should work.
I will plug those numbers into the calculator to see the overall profile change.
Looks like Tire Rack has the Exclaim UHP's for less, including shipping, I will see if Discount Tire will price match.
Thanks Again Maxcichon....
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
JEFASOLD
Nov 14, 2015 10:39 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
tom2112
Jul 28, 2015 08:12 AM
