Skip 1st and 5th?
Old Jul 28, 2008 | 05:05 PM
The Beep's Avatar
Default Skip 1st and 5th?
1st gear on my 05 6spd is really low. I find on most rolling stops, I can take off from 2nd without riding the clutch. Also it seems easy to rev 4th gear up a little farther and go straight into 6th on the freeway ramps.
Anyone else notice this?
Old Jul 28, 2008 | 05:20 PM
CRM's Avatar
CRM
Default Re: Skip 1st and 5th?
Very seldom does my first gear get used, but I do go through the rest of them just to hear the engine!
Old Jul 28, 2008 | 05:29 PM
patpur's Avatar
Senior Member/Moderator
I skip around a lot too. I rather use second in bad weather (ice, snow not rain) to start than first. Skip 5th a lot.
Pat
Old Jul 28, 2008 | 05:47 PM
Chris L.'s Avatar
I might be bi-polar, one minute I'm driving the 6 speed like Mario Andretti & the next minute I'm coasting down a long slope in neutral ( to save the planet)!!!
Old Jul 28, 2008 | 06:10 PM
The Beep's Avatar
I suppose you could use it like a 3 spd and go 2, 4, 6 if you go easy. I might try it when I get home. My last 3 spd was a 68 Camaro with a hurst 3 spd on the floor.
Old Jul 28, 2008 | 06:36 PM
manisusmc's Avatar
i use 1st,2nd then if the speed limit is 50 or so i skip to 6th. if i'm pulling onto the interstate ill run through thris until i hit 70 and then go to 6th
jimf
19
Oct 19, 2015 04:05 PM
jimf
Oct 10, 2015 10:22 AM
Calitony
Sep 24, 2015 12:53 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
csteve0355
Jul 28, 2015 11:12 PM
