Does the battery need water?
Old Aug 24, 2008 | 06:51 PM
anjumkha's Avatar
Default Does the battery need water?
Crossfire 2005 Base
Does the original battery (ade in Spain) need to top off with dist. water?
Thanks
MK
Old Aug 24, 2008 | 07:52 PM
Cobra953's Avatar
Default Re: Does the battery need water?
Yes....pull the caps, and check to see that the plates are covered. Add the distilled water, if necessary. I use a small pen light to see in each cell.
Old Aug 24, 2008 | 08:10 PM
anjumkha's Avatar
Thank you. I never added d/ Water. I will add some tomorrow.
MK
Old Aug 27, 2008 | 07:08 PM
petty's Avatar
Check the battery first it it has caps, if so then you need to add water. but probably, if not it is a sealed battery. Mix baking soda and water and pour a little on the terminals to neutralize the acid that is on them, then rinse it off.
__________________
Autopartswarehouse.com Car Mods.
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
