Warm start issue..
Old Sep 9, 2008 | 01:38 AM
speedman's Avatar
Default Warm start issue..
Hi
I'm Italian and this is mjy first post..so sorry if i talk bad english..
I love US car, Ii had a camaro and now i've a crossfire coupè '04..
Her name is Crossy and all went fine until some weeks ago engine's lamp turn on..
I don't know why.. i've seen on instruction manual that bad fuel could do that..so i've changed oil (mobil1 supersynth), i fill the tank with fresh fuel, but nothing has changed.
Crossy go well, only when the engine is warm, i've to try several times to start the engine..
i've gone to chrysler official assistance, and with their pc-tester they have seen invalid signal from camshaft sensor.
Anyway they don't know so weel this car because in italy crossfire are very rare..
They didn't have the part but while i went to home the lamp turn off..
I don't know why..
the engine lamp turn on and off every 50-60km..is it really that sensor??
when the lamp is off the engine starts regularly also if it's warm.
i feel only rought shifting when the engine is under 2500rpm (automatic transmission).
Someone has had same problem?
My crossy has standard 3,2L engine, i've changed only exhaust and filters (i've put AMG exhaust)
Old Sep 9, 2008 | 06:21 AM
SNAKEWOLF's Avatar
Default Re: Warm start issue..
Just Installed Camshaft Sensor Had Intermittent Light And Code 0341.
After Install All Is Well. I Also Checked Per Service Manual.
Good Luck Wells Part #su6900
Old Sep 9, 2008 | 06:52 AM
speedman's Avatar
Good Luck Wells Part #su9000
Thanks!!
is it difficult to change?
they have to remove engine?
Old Sep 9, 2008 | 06:55 AM
MikeR's Avatar
I had to replace the crankshaft postion sensor on the Aero. I got a CEL with DTC of P0335 and the car would not start. I put the new sensor in and now it starts but I am still getting an intermittant P0335 code and no start. It is quite annoying. The camshaft sensor will do the same no start if it is bad, or intermittant. I am going to try another new sensor to see if I can make my intermittant problem go away.
MikeR
rperry52@live.com
Feb 14, 2019 12:18 PM
minimayhem
16
Aug 23, 2016 07:47 AM
user 8202
Canada
29
Nov 11, 2015 05:27 PM
BEATv1
Sep 10, 2015 12:58 PM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
