Corroded battery tray
Old Sep 13, 2008 | 02:28 AM
Aprilia's Avatar
Default Corroded battery tray
just as well the weather is wet and horrible today... i noticed that furry white substance that is typical of acid corrosion around my battery tray, so out the battery came, out the tray came.
I went up my local auto store and picked up some battery cleaner/acid neutralizer, and some of that rust treatment paint.
Waiting for it all to dry now, so I can reinstall tomorrow.
Anyone use those battery tray mats I found on the net, to keep situations like this from happening???
Old Sep 13, 2008 | 08:16 AM
danimal's Avatar
Default Re: Corroded battery tray
I haven't had a problem with mine. Was/is you battery case cracked? Or, maybe overfilled? That would be the only way to get corrosion that bad from the battery acid (that I know of). I have heard that the mats are pretty good at absorbing acid, etc. and would be worth a try under the circumstances.
Old Sep 13, 2008 | 01:58 PM
Chris L.'s Avatar
Do Austrailians shift with their right hands or left hands (steering wheel on the right side of car)?
Old Sep 13, 2008 | 06:21 PM
Aprilia's Avatar
Hey Danimal
I could find nothing wrong with the current battery, but as I've only owned the car about 3 weeks, I can't say what the situation was before that - but likely a previous battery. I just thought a mat might be a good idea to protect my hard work! Didn't know the mats existed until I searched the net, looking for a replacement battery tray...
Justin
Old Sep 13, 2008 | 06:22 PM
Aprilia's Avatar
Hi Chris L
We shift with our left hand. We sit in the right side of the car, and drive on the left side of the road - total opposite to some European countries, some Asian countries, and the US of A.
Justin
Old Sep 14, 2008 | 03:04 AM
danimal's Avatar
Originally Posted by Aprilia
Hi Chris L
Justin
That did take a little getting used to when I was there in Perth/Freemantle some 25 years ago........but very beautiful area. It was the first place that I found right drive Corvettes. And I always forgot which way to look crossing the street after coming out of the wine bar...LOL.
Old Sep 14, 2008 | 04:52 AM
ppro's Avatar
Damage to cars from battery corrosion happens fast and is often devastating. I would recommend not fooling around with present battery or pad.
Using a pad assumes you have a leak which will not be solved by the pad. Once the alkalinity of the pad is neutralized, the problem will continue.
I suggest rather a good gel cell battery that is completely sealed and cannot leak - like the Optima battery. Yes, expensive but compared to a perforation of the chassis rail beneath the battery from corrosion...?
P.S. The battery acid neutralizer you bought is water and baking soda mixed. Far cheaper to make your own. It's a good tactic to clean up with it, and then wash with fresh water making sure that all traces of both battery acid AND neutralizer solution are gone.
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
maxcichon
Sep 28, 2015 07:34 AM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
