crossfire is a problem right now
Old Sep 19, 2008 | 05:21 PM
XfireX's Avatar
Default crossfire is a problem right now
the other day my brother was walking to his 2004 ltd. crossfire and as he turns the key all the way the engine will not start...so i reset the computer and the car starts for a breif second and shuts back off and will not start again unless i reset it... does anybody know what the problem could be because autoshops it was sent to by tow truck can not figure out the problem and chrysler dealership wants $150 just to figure out the problem...could it be the rellay control module or the oxygen sensor?
Old Sep 19, 2008 | 06:02 PM
MikeR's Avatar
Default Re: crossfire is a problem right now
Is it throwing a CEL? You need to get the DTC read out. I had/have a problem with my crank positon sensor that causes the car not to start. Sometimes it just seems to start at the end of the cranking and doesnt catch. It always throws a CEL when it does this or it doesnt start. P0335.
The crank position sensor is on the back of the engine by the bell housing, drivers side. You could try unplugging it and plugging it back in and see if it makes any difference. Mine seems to have an intermittant connection/contact problem still and occaisionally wont start unless I fiddle with the connector.
MikeR
p.s. make sure the engine is COLD.
Old Sep 19, 2008 | 07:09 PM
Stogey's Avatar
There's been several relay control module failures it seems with the 04's and most have similar symptoms.
Relay Control Module Failure
1) All accessories are operable when the key is turned to the ON position with the exception of the fuel pump
2) When the key is toggled to the START position the starter does not engage
3) Mostly happens when the engine is at running temperature
4) Can sometimes be temporarily remedied by rapping the side of the RCM containment housing with like the handle of a screwdriver
Compare these symptoms to what is happening to your brothers car. If the starter engages and the engine turns over but does not start then most likely the problem is elsewhere.
Hope this helps, you may also wanna do a search on Mystery No Start or Relay Control Module or Crank Position Sensor for more info.
Good Luck !
Old Sep 20, 2008 | 02:32 AM
antonio311's Avatar
Talking Re: crossfire is a problem right now
"Can sometimes be temporarily remedied by rapping the side of the RCM containment housing..."
Do you really think rapping to the containment housing is gonna fix the problem?? I mean i'm a fan of Ice T but come on!
Old Sep 20, 2008 | 03:59 AM
Stogey's Avatar
Noooooo, maybe you misunderstood, if you're stranded on the side of the road, work or whatever, sometimes giving the containment a good whack will get you home or to the dealer. It is definetly not a fix !!!
The operative word here is "Temporarily" !
Now, ask me how I know this ???
Old Sep 20, 2008 | 01:52 PM
antonio311's Avatar
Oh, I thought you wanted us to Rap, (you know) spill some words to fix the problem.
Old Sep 21, 2008 | 04:33 AM
Stogey's Avatar
Just as " dancing "... white boy can't "rap" !!! Geez !
Old Sep 22, 2008 | 10:51 AM
The Beep's Avatar
The problems with this thread are worse than the problems with your car!
Old Sep 22, 2008 | 09:19 PM
antonio311's Avatar
yep!!
Old Sep 23, 2008 | 03:12 AM
apkano's Avatar
Life is random...so am I.
You have to admit though...it does bring up some interesting mental images! Right now I have the one where Vanilla Ice is dropping some rhymes under his hood on the side of the expressway, silly dance and all!
Old Sep 23, 2008 | 08:41 AM
tighed1's Avatar
Just saw this problem on the forum yesterday. I'm gonna sound like guys' that have been here forever...but a quick search turned up the following.
https://www.crossfireforum.org/forum/...ad.php?t=27288
Has the part number you need and what it should cost you.
good luck with the fix!
BEATv1
Jul 16, 2015 09:40 AM
wbaker1970
Jun 17, 2015 08:57 PM
BEATv1
Jun 12, 2015 05:20 PM
racingagent
Jun 8, 2015 07:29 PM
MJPowers
Jun 8, 2015 02:34 AM
