burnout video
Old Oct 15, 2008 | 01:39 PM
makeithappen's Avatar
Default burnout video
this is not me but i found it on youtube its crazy. i wanna know whats on his tires cuz my cars emergency break cant take all of that haha
http://www.youtube.com/watch?v=SsOK-...eature=related
Old Oct 15, 2008 | 01:48 PM
ZAHANMA's Avatar
Default Re: burnout video
don't know specifically for that video, but i have heard of people using plain water... or i've heard of people using bleach although the chlorine gas that is a result of that is never a good thing....
Old Oct 15, 2008 | 02:49 PM
Kit Fox's Avatar
Tire shine stuff you put on your wide walls, there is a reason why it says on the bottle not to put on thread
Old Oct 15, 2008 | 03:29 PM
ppro's Avatar
There's somebody who definitely has not
Basically on two counts, tire & e-brake destruction notwithstanding
- Manual says not to spin one wheel - causes problems with drive train
- manual says problems arise from spinning rear wheel(s) if ESP is enabled.
Consequences are transmission, drive train and rear differential.
I wouldn't give you a nickel for that car. Well maybe 10 cents for a couple interior parts I need...
It's definitely fun to watch someone else trash their own car though...
Old Oct 15, 2008 | 05:19 PM
downwardspiral's Avatar
Emergency brake? Are you talking about the crossfire?
Old Oct 16, 2008 | 12:00 PM
yeah the crossfire does have an e-break. it says he goes through all 5 gears. the e-break and much more would be burnt.
Old Oct 16, 2008 | 12:05 PM
Kit Fox's Avatar
I'm not a burnout expert but you dont use the e-brake for a RWD car. Not sure on the crossfire but on most cars the e-brake is a drum brake inside of a disc brake basically. For a RWD car you basically press normal brake down gently enough to stop the front wheels. The front wheel brakes are much stronger then the rear.
Old Oct 16, 2008 | 12:09 PM
damn. i think ur right haha.
but he is ripping apart the breaks. you can see the car start to go side to side at a point. just a bad thing to do to your car.
i have a 6 speed so the whole holding the break and letting off the clutch and hitting the gas all at the same time is kinda difficult haha
Old Oct 16, 2008 | 12:11 PM
MikeR's Avatar
Why would he even have the e-brake on? All that would do is add resistance to the tires he is trying to spin. Glad he is buying the tires..
MikeR
Old Oct 16, 2008 | 01:11 PM
No Warning Shot's Avatar
LOL it's not that hard. I've put on a few smoke shows shows myself without having to use anything to help spinning the tires. The stock Conti's dont grip for crap anyways. All you gotta do is rev it up, dump the clutch, and apply the brakes quickly while keeping the gas mashed. Not very good for the car but what's a little fun once in a while.
I'm not sure if both rears spun or not.
Old Oct 16, 2008 | 02:22 PM
JHM2K's Avatar
I saw this video before, and I still stick to my original conclusion:
Think about it. The amount of time it takes to wind out each gear in every other car INCREASES with each shift. This is due to a couple of reasons...
1) The gears get progressively taller
2) The increasingly taller ratio will make the car have to work harder at the same RPM, especially in a "standstill", "brake-torqued" situation
The X-fire in the vid blasts through all gears at the same rate. Auto or not, I can't see the engine's torque compensating for the steep angle of the later gears.
Launch your car @ 2,000 RPMs in 1st gear. Now, try doing the same in 6th gear, from a standstill. Unless you're driving a Viper with 500+ LB/FT of torque, you're stalling in a heartbeat.
While the Crossfire is torquey, it isn't THAT powerful to be able to sustain smoking the tires through five gear changes.
Let's just say for grins and giggles that 1st gear is 2.80 ratio, and 5th is .95 .... you're not going to accelerate through the final gear as quickly as you would the initial one, unless the car is on a lift.
Here's a video of a TRUE multiple-gear burnout... clutch shifts and all. A keen ear will recognize the slower ascension in RPM as the gear number gets higher.
http://www.youtube.com/watch?v=NF2p2Vy2POo
Just my
Old Oct 16, 2008 | 02:41 PM
MMZ_TimeLord's Avatar
I think he just did 1st gear 5 times...
Old Oct 16, 2008 | 02:56 PM
JHM2K's Avatar
That makes one person that agrees w/ me... hehe
Old Oct 16, 2008 | 06:43 PM
Two people, the same thing happened to me the first time I tried, my car is stick, so Im pretty sure it didn't shift up. And yeah, nowhere near enough power to spin the tires in 5th.. without the TC, 2nd would be tough.
Old Oct 16, 2008 | 06:51 PM
tighed1's Avatar
You don't use the e-"break". You mash the brakes and hit the gas. Front tires hold the car and the torque over powers the rear brakes and the tires spin.
Used to do it with my Ma's Pinto.
Don't tell!
Old Oct 16, 2008 | 07:04 PM
I called BS on this video and commented to him about it. My s/n is bigtruck8622 on YouTube. I told him all he was doing was hitting the rev limiter in 1st five times but he insists it was five gears lol.
Old Oct 16, 2008 | 07:22 PM
manisusmc's Avatar
in watching that video and clicking on a few more i came to this
http://www.youtube.com/watch?v=c9yfa...eature=related
Old Oct 16, 2008 | 07:25 PM
robby363's Avatar
Here's one that will get you to school on time. http://www.youtube.com/watch?v=9N2eHWHuDQM&NR=1
Old Oct 17, 2008 | 03:38 PM
stryfox's Avatar
It pulled out real nice in 5th gear hahaha
B.S.
Old Oct 17, 2008 | 05:38 PM
Holy crapp
Better be careful if yur standing at the bus stop ...lol
