Power hatch lock repair
Old Jan 15, 2009 | 01:42 AM
CALL911's Avatar
Default Power hatch lock repair
My rear hatch lock failed during a cold snap a couple of weeks back. (thankfully in the unlocked position) I didn't want to hassle with taking it to the dealer under warranty, so this is what I found.
1. Traced vacuum leak to the hing area of the pass. side hatch.
2. Separated the rubber gasket that goes between hatch and body.
3. Found that they use a yellow PLASTIC hose, and it cracked in half. (very poor design)
4. I used a piece of rubber vacuum line to reconnect the two halves. (due to lack of extra line and other wires I used a pair of needle nose pliers to hold the plastic line while I slid the vacuum hose on.)
5. Reattached rubber gasket.
Total time, about 10 min.
This is most likely what the dealer would anyway, as I cannot see them replacing the whole line, and this will last ! If they did replace the whole line, it would probably break next winter anyway.
Hope this helps.
Old Jan 15, 2009 | 06:28 AM
Punkin's Avatar
Default Re: Power hatch lock repair
Thanks for the write up. It will happen to many. Maybe the moderator can move this to the fix it area.
Old Apr 18, 2015 | 11:31 PM
funnybunchofitalians's Avatar
Hope this helps.
How did you remove the plastic trim off the hatch?
(Sorry for revoking such an old thread. )
Kodebuster
Nov 5, 2020 04:06 PM
crmnal
Sep 6, 2015 08:07 AM
MAXIMUM
Aug 4, 2015 11:04 PM
waldig
Jul 15, 2015 02:05 PM
