door panel removal
Old Apr 20, 2009 | 10:16 AM
ryan48's Avatar
Default door panel removal
Do I need to unplug any thing before removing the door panel?
Old Apr 20, 2009 | 10:20 AM
Stogey's Avatar
Default Re: door panel removal
Unplug the battery and allow to set for a few minutes, this will insure that you don't accidently deploy the air bag in the door !
Old Apr 20, 2009 | 10:21 AM
blackcrossfire07's Avatar
Everyone says to disconnect the battery so the airbag doesn't accidentally go off. Not sure if that is true or not.
Old Apr 20, 2009 | 11:52 AM
nox1s's Avatar
I've taken my door off many many times and never unplugged the battery. You need to disconnect the door pin by sliding it under the hole, and the tweeter by unclipping it. It's pretty obvious once you've gotten this far.
The tweeter is actually mounted on the door, and the speaker is mounted on the door frame, hence why you need to disconnect one and not the other.
Old Apr 20, 2009 | 12:03 PM
tighed1's Avatar
https://www.crossfireforum.org/forum...+panel+removal
PNA
Nov 12, 2020 04:44 PM
pioneer4x4
Mar 25, 2019 10:35 AM
rocketrage
Oct 7, 2015 05:00 PM
flame
Aug 19, 2015 04:06 PM
PHeez
Aug 11, 2015 01:30 PM
