Windshield Washer Spray Adjustment??
Old May 6, 2009 | 10:48 PM
BRappaport's Avatar
Question Windshield Washer Spray Adjustment??
Does anyone know if there is an adjustment to aim the windowshield washer spray nossles? Mine seem to be low and always hit the wiper blade arm. Is there a way to aim or adjust the height...or change the spray pattern from a stream to a wider spray pattern?
Does anyone else have this problem?
Thanks,
Ben
Old May 6, 2009 | 10:59 PM
Waynesworld's Avatar
Default Re: Windshield Washer Spray Adjustment??
I used a pin to adjust the aim on mine.
The spray nossle moves in the block.
2 people makes it easer.
This worked for me
Old May 6, 2009 | 11:00 PM
blackcrossfire07's Avatar
I have the same problem. It doesn't spray like it used to.... now it is just a stream. I am curious to hear of a fix. I am sure you can adjust the nosle.... maybe it is dirty. I just never took the time to figure it out.
Old May 7, 2009 | 06:49 AM
winstonscifi's Avatar
Yeah, I was wondering too. My driver side nozzle is more toward the center of the windshield. I'd like it to be toward the left (as I'm looking at it). Would a couple of pins in the holes, and forcing it gently to the left work?
Old May 7, 2009 | 07:41 AM
danimal's Avatar
A paperclip works great.
Old May 7, 2009 | 08:27 AM
mrphotoman's Avatar
This worked for me
I didn't know that, I will have to remember that if I ever need to adjust mine!
Old May 7, 2009 | 09:18 AM
Tim2739's Avatar
Old school...
Old May 7, 2009 | 02:34 PM
OKC-XFR's Avatar
I'm not sure if mine even works...
Old May 7, 2009 | 02:46 PM
Montana Crossfire's Avatar
Ben, Remember when you do your adjustment, do not adjust them to high. This is a typical mistake made by adjusters. They adjust while sitting still only to find out the spray shoots over the car when driving at high way speed.
Mike
Old May 7, 2009 | 05:41 PM
green-ghost's Avatar
my 95 talon had a rear washer that I set to spray up and out about 10 feet, it was the best mod for las vegas tail gaiters
Old May 12, 2009 | 10:19 PM
BRappaport's Avatar
Mike
Mike,
Thanks for the tip. Did my adjustment today...and it did take several tries to get it positioned right. I have them right now...I hope they stay that way.
Do you have to re-position them often...or should they stay put?
Also...can you get a spray...instead of a stream? If not...is there a replacement nossle you can get that will give you a spray pattern?
Thanks again for everyones comments,
Ben
Old May 13, 2009 | 07:41 AM
Stogey's Avatar
Seems to me a stream would be more effective than a spray at highway speeds.
Old May 13, 2009 | 10:56 PM
CALL911's Avatar
One of my minor complaints about this car, The washers suck.
Old May 13, 2009 | 11:09 PM
Tom1957BigT's Avatar
I used to have a talon...it was a great car while it lasted.
55chevy
Jul 22, 2024 02:31 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
debradegiovanni
Sep 27, 2015 09:39 AM
Sep 26, 2015 10:21 PM
BEATv1
Sep 10, 2015 12:58 PM
