Shift Kits? Looking for Hard shift from 1-2 for a nice CHIRP
Old May 8, 2009 | 05:11 AM
sorr10's Avatar
Default Shift Kits? Looking for Hard shift from 1-2 for a nice CHIRP
I have searched far and wide through this forum before posting this. I hope I did not miss anything. I love when you have your pedal floored and it chirps when it changes gear from 1st to 2nd on the Automatic transmission. I have the stability control button turned off and I can get my rear wheels to spin from a start but I want that nice hit when it changes to 2nd. I have owned a 2004 limited now for just over a month and within that month it has done it twice (trust me I have tried reproducing it many many times with no avail. Is there a little trick I can do to get what I am looking for, like a shift kit or ECU tuner kit or anything to get said result?
I have tried manually shifting with the auto stick with no avail.
Any Ideas?
If this has been discussed before somewhere in the forums, I am sorry but I searched and searched many different phrases and words with no conclusion about what I am looking for. If it has been discussed, please accept my apology.
Old May 8, 2009 | 09:03 PM
07bluezx14's Avatar
Default Re: Shift Kits? Looking for Hard shift from 1-2 for a nice CHIRP
I probably wouldn't get into the tranny. It sounds like you need to get intouch with TVT. I think that your initial tune, is 500 bucks, but if you buy the cables from them, you can flash your cpu with a downloaded tune via laptop. I really want to get their 265 kit, but crap just keeps screwing things up. That is my suggestion. goodluck, chris
Old May 8, 2009 | 09:12 PM
I tried to look into this some time ago, but no luck. The car has so many sensors built into it to make it smooth shifting and handling...not sure a shift kit will make a difference unless those controls are completely turned off. Even though you turn the TC off, it really really isn't off. It will override...so pulling fuses or wiring a switch in line may be in order...
Old May 9, 2009 | 12:03 PM
AllEuro's Avatar
The solution to your problem?
Sell your car and buy one with a manual! I've definitely had a few times where I shifted hard into second and tct ctrl was blinking and you could feel the rear end get squirely.
I'm going to side with "doc" on this one. You're driving a mercedes which is a generally a very conservative brand when it comes to how systems are calibrated. Just look how sensitive the tct ctrl is and how stability ctrl can't be fully deactivated.
massanu
Feb 20, 2019 07:06 PM
MiamiTVR
Jan 30, 2016 02:15 PM
smokey847
Nov 12, 2015 11:54 PM
ayebb
Sep 18, 2015 03:35 PM
brandoni
Sep 6, 2015 07:35 PM
