Tire pressure question
Old Oct 27, 2003 | 08:18 PM
glennnn's Avatar
Default Tire pressure question
When I got my xfire the front tires had 27psi and the rears 30 psi. The label inside the drivers door says 32 front/33 rear. I put 32 all around and the ride is very bumpy. Is the 32/33 a recommended or a max? What pressures do other owners ride on?
Old Oct 27, 2003 | 08:56 PM
mouserider's Avatar
Default
Which tires do you have? Pilots or Continential A/W?
32/33 is the recommended ride pressure for the Pilots. At 27psi, my low pressure warning would come on for sure. It came on when the weather here cooled down and cold pressure read 29psi on the fronts.
I would not run the Crossfire at 27psi, the Pilots are performance low profile tires. Running it at those low pressures could seriously increase wear on those tires and potentially cause damage to your rims as well. It could be a safety issue as well.
Old Oct 27, 2003 | 10:18 PM
imported_mightyjlr
Guest
Posts: n/a
Default
I actually had the tire pressure warning light go on this weekend. My left rear tire was all the way down to about 15 PSI. I'm a little worried there might be a leak or something, because all of the other tires were around 32 PSI. I thought it might have been because it was a cold day, but I don't think so because it was only one tire. I might have the dealer check for leaks.
Old Oct 28, 2003 | 03:15 AM
mouserider's Avatar
Default
Oh man, those rears are expensive, hopefully it is a fixable problem.
Old Oct 28, 2003 | 04:38 PM
texex91's Avatar
Default
15 PSI is wayyy low. I'd definately have them check fleak--sounds like a small leak is probably occuring. Let us know...
Old Oct 28, 2003 | 07:42 PM
glennnn's Avatar
Default Tire Pressure question
Thanks for the info. The tires are Pilots.
Old Oct 28, 2003 | 09:32 PM
eurodirt's Avatar
Default
How much are those tires? Is there any place to buy them at a bargain price? I rarely drive my car, I bought it as a special event car and not a driver...last time I drove it though, that tire light came on.
Old Oct 28, 2003 | 09:46 PM
crossfiretech's Avatar
Default
tirerack.com
Old Oct 29, 2003 | 09:23 PM
imported_mightyjlr
Guest
Posts: n/a
Default
This sucks... my tire pressure light came on again. Didn't have time to go to the gas station and fill it, but I will first thing tomorrow. I'll take it to the dealer on Friday... maybe I'll get a new tire considering it only has 2200 miles on it. Maybe. Don't feel like already spending $320 on a new tire.
Kodebuster
Nov 5, 2020 04:06 PM
Danyuhl
Nov 2, 2019 05:18 PM
PimpDaddy
Sep 29, 2016 11:55 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
axnguyen
Jul 21, 2015 11:41 AM
