GPS Mount
Does anyone have pics on where you have mounted your GPS? I'm looking for some ideas.:rolleyes:
Re: GPS Mount
You might start here:
https://www.crossfireforum.org/forum...uvi-350-a.html Proclip is the only way to go....in my personal opinion. Have a mount for each vehicle so that I can take my Garmin everywhere.:) |
Re: GPS Mount
My wife made this one. Velcro holds the GPS to the bag, the bag has a non-skid pad sewn onto the bottom. Take it from car to car with no problem.
https://www.crossfireforum.org/galle...500/GARMIN.jpg |
Re: GPS Mount
Thank you for the Pro clip site, ordered one for my car & one for my wifes. Thanks again:D
Re: GPS Mount
This is the way I do it....
Mount can be found at Amazon.com: Arkon GN047 Removable Vent Mount for Nuvi & StreetPilot: Electronics https://www.crossfireforum.org/galle...i_Mount_21.JPG |
Re: GPS Mount
I've got a TomTom OneXL and it has an integrated suction cup mount, so I mount it on the windshield of which ever vehicle I'm using at the moment.
Re: GPS Mount
Re: GPS Mount
no pics, but I suction cup mine on the glove box....
Re: GPS Mount
I suction cup mine on the dashboard, right over the speedometer. who needs to watch the speed anyways. :p
Re: GPS Mount
Suction cup that came with my nuvi. On the window between the A pillar and bump thing in the dash.
Re: GPS Mount
Suction cup to classic position, center windshield low.
James1549, what's in the bag to give it weight so it does not shift around? I've seen the beanbag mounts but they cost $59 and I won't spend that much to replace a perfectly good suction cup. |
Re: GPS Mount
Re: GPS Mount
Does anyone have a good close-up picture of the Pro-clip mount that mounts lower on the right side of the console , angled at the driver? If so, could you please post some picks? Thanks
Ben |
Re: GPS Mount
I decided against that lower mount just because I didn't want to have to look down to see the GPS. With the upper mount, it is almost at eye-level and only requires a quick glance. It is also much easier and faster for the GPS antenna to get satellite fixes, and it is easier to hear the directions because the speaker is not down in the footwell.
Just a few things to think about..... |
Re: GPS Mount
Just a few things to think about..... Is this air vent holder more secure? Also...can it be easily put on and removed...I only want it there if I am using the GPS. Also...does the clip scratch the paint? I do like the mount higher at eye level as you mentioned. That is ideal as long as it is sturdy. Thanks, Ben |
Re: GPS Mount
It is probably the sturdiest mount available and doesn't attach to the air vent itself. I'm not sure why you would want to remove it but to each his own. As you can see in acrispy1's photo it clips inbetween the panels. Constant removal would most likely end up marring the panels. While not a permanent mount, I consider it as such. It does come down in front of one of the center vents but it does not block it.
