Tread Wear and Rotation
Old Nov 4, 2003 | 05:55 PM
X-fired's Avatar
Default Tread Wear and Rotation
So how are the tires wearing? I have 3,500 miles so far and wear seems to be pretty even - haven't measured tread depth. Have any of you rotated yet? How did the tires look and what did you pay?
Old Nov 4, 2003 | 06:03 PM
kraz17's Avatar
Default
i have around 3,000 miles on mine. the side of my front tire bubbled out a bit. the dealer just ordered me a new tire.
Old Nov 4, 2003 | 08:11 PM
kusheen
Guest
Posts: n/a
Default tire rotation
Just had the car in for a first oil change at 1700 miles, just to get the breakin oil out.
While it was there, had them rotate the tires. No wear as yet, but just being ****.
Old Nov 6, 2003 | 10:51 AM
powellc's Avatar
Default
What is rotating? is this what we call wheel balancing in the UK?
Old Nov 6, 2003 | 11:11 AM
X-fired's Avatar
Default
Rotating is swapping the tires from side-to-side to even out the wear. Typically rotation is front-to-back but since the Crossfire has dissimilar diameter wheels, they are swapped side-to-side.
Old Nov 6, 2003 | 11:26 AM
powellc's Avatar
Default
So I take it that the tyres are removed from each of the wheels and swapped around? The garage doesn't just swap the wheels around does he otherwise I wouldn't see the benefit. (How would you know of course)
Another thing, how often should someone do this?. Once a year?
Chris.
Old Nov 6, 2003 | 11:31 AM
WesMichaels's Avatar
Default
No..... The Tires are NOT removed from the wheels. The wheels and tires are moved from one side to the other as an assembly. Crossfire wheels are not directional like some Corvette wheels.
Old Nov 6, 2003 | 11:43 AM
X-fired's Avatar
Default
Correct, tires are non-directional but are also asymmetrical meaning the outside portion of the tread is different from the inside portion, enabling side-to-side swapping. I usually rotate about every 5,000 miles but may rotate these spendy buggers more often.
Old Nov 6, 2003 | 11:47 AM
powellc's Avatar
Default
Then I don't see the point of rotating wheels with the Crossfire as surely the weight will always be on the outside rim of the tire. Rotating them in the crossfire will not change this so I cannot see how by rotating the tires would even out wear?
I suppose I don't need to understand it but is it worth it?
Cheers,
Chris.
Old Nov 6, 2003 | 12:25 PM
adf3786's Avatar
Default
Depends, you may only ever turn left!!.
Seriously believe it or not, you do tend to get one side wearing more that the other. I was always griping with the SAAB garage because they NEVER rotated the tyres. I had a high pressure Turbo 2.0 Litre, front wheel drive. Pretty quick but one of the front tyres always wore unevenly to the other.
Old Nov 6, 2003 | 10:37 PM
Judy's Avatar
Default
I am in the final stages of locating a Crossfire to purchase. My plan is to buy a automatic. However, I am undecided on the tire selection. Anyone have experience with the Continental all-season relating to handling & wear? Also, any opinion if they will wear better than the Pilots'? I don't plan on any high-performance, hard driving. Nor do I plan to drive this car in the winter (Ohio resident). I'm looking at this as being more of a touring car.
I also talked to a friend who owns her second SLK. She told me that the SLK has a monitor that tells her when to change the oil. Does the Crossfire have this also?
Thanks again for your feedback.
Old Nov 7, 2003 | 06:14 AM
kusheen
Guest
Posts: n/a
Default yes
The car has a monitor that will tell you (but you have to 'ask' it) when your next service is due.
Old Nov 10, 2003 | 04:40 PM
robby's Avatar
Default
mine have 8000 miles and they seem good still....
Old Nov 13, 2003 | 12:38 AM
jokers777's Avatar
Default bubble on sidewall
Had bubble on front tire sidewall, michelin says i hit a pot hole, not covered. Went to dealer , he called chrysler they got me a tire in about 2 weeks. No charge! Chalk one up chrysler & the dealer.
Old Nov 19, 2003 | 02:24 PM
sfxfire's Avatar
Default
Lots of good advice given so far but can anyone with experience and knowledge of these tires tell us how long (with proper MTCE) do these tires actually last before replacing them?
I live in an area with no winter snow just rain so these tires remain on my vehicle year-round.
Thanks,
Sapphire Blue 6 spd
Old Nov 19, 2003 | 03:37 PM
X-fired's Avatar
Default
I did a quick check of the TireRack reviews and found some who said they were bald after 15,000 miles and some who said they had 36,000 miles on them. As they say, "your mileage may vary."
Old Dec 2, 2003 | 07:26 PM
thrilled's Avatar
Default
Am I correct that the OEM Michelins can run in one direction (for example clockwise on the psgr side) but when rotated to the other side there is no tread or structural damage caused by now running in a counter-clockwise direction?
Does this now mean we cannot put directional tires on because at some point, if one rotates them, they will now be pointing rearwards? Will one get more benefit from directional tires but trade them off for the inability to rotate?
deerhunter
Jan 16, 2021 10:56 AM
Kodebuster
Nov 5, 2020 04:06 PM
ritous1
Sep 26, 2015 01:27 PM
cdcrone123
Sep 20, 2015 10:02 PM
cjfine
Jul 20, 2015 11:58 PM
