Does Anyone's Engine Shake
Old Nov 15, 2009 | 01:58 AM
trent_850's Avatar
Arrow Does Anyone's Engine Shake
My Engine Shakes When Turning The Car Off.
Is That A Problem Or Do Crossfires Just Do That
Old Nov 15, 2009 | 04:36 PM
samo59's Avatar
Default Re: Does Anyone's Engine Shake
Depends on what you mean by "shake". If its a violent shudder that you can feel throughout the car, then thats not good. If it's a light shake then that shouldn't be a problem. If anything is wrong it could be a motor mount but usually it takes a while for those to wear out. Wait and see what others have to say...
-Sam
Old Nov 15, 2009 | 04:55 PM
shapeshifter309's Avatar
Eh, mine gives a little wobble while it's on. I'm assuming that's normal.
As for turning it off, I don't feel mine shaking at all. Do you have a manual? Push the clutch in before you turn it off. That usually keeps mine from doing it.
Old Nov 15, 2009 | 05:19 PM
you need to check the motor mounts...some early models had motor mount issues
Old Nov 15, 2009 | 07:50 PM
trent_850's Avatar
Ist not a bad shake its like when you turn the car on...its an automatic
Old Nov 15, 2009 | 09:23 PM
cassidyrj1's Avatar
I use to have a horriable shake when I would start my car. I got it fixed but was never told what it was. I now have a small ticking noise and a very small shake but nothing that seems un normal.
Old Nov 18, 2009 | 07:05 AM
Glockhit's Avatar
Only when I have a fat bi-polar passenger with hemorrhoids. Although now that I think about it so does the whole car. Hope this helps.
Old Nov 18, 2009 | 08:59 AM
mdaniels4's Avatar
the shake that people describe on shut off usually is engine dieseling which is caused by improper fuel mixture, maybe motor mounts but i've had those loose and they show up in other areas of driving, not just in shut off.
jgreen
106
Sep 18, 2017 11:46 PM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
