Using the "auto-stick" feature??
Old Jan 9, 2004 | 04:08 PM
CCrossfire's Avatar
Default Using the "auto-stick" feature??
I have never had a slap stick car and the Crossfire being my first I was wondering how every one is using it and if it's "enjoyable"? Thanks - Bob
Old Jan 9, 2004 | 05:08 PM
lordpercy's Avatar
Default
its quite good i only use it in one circumstance when i want to power past something or out of a corner it eliminates the lag on the pedal, i find it doesnt drop enough cogs when you floor it.
Basically i hold the stick to the left, power on full change up gears manually until i reach the desired cruising speed (60 - 80mph) then drop back to auto mode.
Not sure i'd use it in any other way?
Old Jan 9, 2004 | 05:16 PM
jsisabella's Avatar
Default
I actually use it quote often, and I really like it.
Downshifting on an off ramp to slow down
Shifting up through the gears when you need (or just want!!) that extra bit of pep
Then just go back into auto for regular city stop and go driving
Plus, my wife would never drive a manual.....
Old Jan 25, 2004 | 09:31 AM
lordpercy's Avatar
Default
went for a drive toady only used autostick feature, good fun apart from change between 1st to 2nd seems a bit sluggish anyone else get this? or is it just that 1st is a short gear, it almosts seems that you need to change a bit before you want the gearchange?
Old Jan 25, 2004 | 09:58 AM
texex91's Avatar
Default
Go try it that's what it's there for--it's actually quite fun.
Old Jan 25, 2004 | 10:40 AM
AZ Outlaws's Avatar
Default
Maybe, "just Maybe you should of gotten a 6-Speed... that way you'd have the car to yourself.... :twisted: :wink: :twisted: :wink:
Old Jan 25, 2004 | 12:47 PM
CCrossfire's Avatar
Default
Thanks for the comments. I "slapped" mine around this morning dropping two ranges from drive at about 50mph and stepped on it, exhilarating - shifted it back to drive ending at about 70, lotsa fun. Seems quicker than just flooring it as I experienced no torque converter lag prevalent in other automatics I have owned.
Old Oct 30, 2015 | 08:44 AM
04crossblack's Avatar
Default Re: Using the "auto-stick" feature??
anyone able to tell me what type of delay you get between gears with the slap stick. on my automatic there is a delay between slapping it and it actually shifting. not an instant (or close to it) as a real manual. could It just need a trans fluid flush and new gasket? which I already have planned.
Old Oct 30, 2015 | 09:09 AM
There is a slight delay on mine as well mostly shifting 1 2 3 4 5 and I think this is common on most all of these
5 4 3 2 1 is a little more responsive
I have had mine for 8 years and driven several others as well and found no difference really
Old Oct 30, 2015 | 09:10 AM
zip439's Avatar
I do not notice a delay in mine. It may be a half second, but I haven't noticed. I keep my hand off the shifter until I intend to use it as the throw, or movement required to make the shift, is very short and I find myself shifting inadvertently as my body weight shifts in a turn. I did have the transmission flushed at 70,000 mi by a local Mercedes dealership. Mine shifts fast and precisely at the slightest movement of the shifter.
Old Oct 30, 2015 | 10:14 AM
pioneer4x4's Avatar
I haven't driven an automatic Crossfire, mine and the others I test drove were all 6sp. But I did have a 2006 Charger R/T for 7 years, and its auto-stick was far quicker and better overall compared to any other I have driven. I also got a Diablo Sport tuner for it and you could alter the chip points, and firm up the shifts a bit. It worked very well, but really wasn't needed. I felt the factory setup was a great balance of use and everyday drivability. Does anybody here have experience in the LX cars, and the Crossfire to compare shifting?
Old Oct 30, 2015 | 02:50 PM
''I get your problem. really.
I am THE roadster with a stick guy and use the shifter as a hand rest. My manual shifts smoothly and with complete automation. The **** acts superbly as a hand hold during High speed turns thru the twisties.
Then I get in the wife's SRT6 and find my hand constantly confusing the tranny.
But, once you get used to the thing, it is a remarkable shifter. And after sometime with it, you will find it not only shifts smoothly when you anticipate it, sometimes it does it for you. The tranny" "learns' how you drive and anticipates your inputs.
I still prefer the manual, but the power of the srt is addictive. And the response of the tranny, even in the NA, makes the crossfire a pleasure to drive. Just learn to put your hand on the console and bump shift it with your thumb.
Do this if for no other reason than to prevent a sudden autonomic thrust of the shifter into third for a passing maneuver. Putting the shifter into that position is "PARK"
I don't think the computer program has cuss words in it's vocabulary but if it did,, you would hear all of them pronounced loudly.
Fortunately nothing happens and your passenger will just laugh. And later tell all your friends. Don't ask me how I know.
Old Oct 30, 2015 | 03:23 PM
Padgett's Avatar
I just use the manual stick feature. OTOH my Jeep has the same 5-speed automagic and is quite responsive in the mountains.
Old Oct 30, 2015 | 09:36 PM
Da55id's Avatar
Or, you could get the paddle shifters and feel like the king of the world ��
Old Oct 31, 2015 | 12:14 AM
+fireamx's Avatar
I use to think that "Paddle shifts" were really only needed in Formula One cars (due to space restrictions), But in a Sports Car, it was just a gimmick. I was pleasantly surprised at how cool they actually are a couple years ago while enjoying the beautiful roads of Sequoia National Park, Calif. driving a Lexus IS350.
I still prefer my 6spd to the Automatic, but after driving Gene's (Sandman50) XF thru the Dragon, I have to admit it does make it a lot easier to negotiate those curves quickly. Not as much fun (to me) but easier.
Old Nov 2, 2015 | 08:29 AM
crymar's Avatar
Default Auto-Stick Makes Up for Sticky Transmission
I drive quite conservatively and normally don't use the auto-stick, but I'm glad I have it because it allows me to resolve a shifting problem. The trans in my '04 coupe (32,000+ miles) has the irritating habit of sticking in gear (any gear) once every few weeks if I cruise at lower speeds for any length of time. For example, if I'm creeping along (such as looking for a house address) for a few minutes, the trans will stay in 2nd when I accelerate. At various times it has stuck in 3rd and 4th gear too. It's not a real problem but more of an irritation as it happens so infrequently. When it does, I simply tap the auto-stick to put it back into Drive. It's been doing this since I bought the car four years ago. The trans went into limp-in last year, so I installed a new conductor plate and adapter socket and changed the ATF (Shell 134) three times (drain and refill). It works fine now but still sticks occasionally as before. I have a new trans controller ready for installation, but I can go weeks without the trans sticking in gear, so it's not crucial that I install it now. Other than this the car's been perfect and we love it. I wonder if anyone else has experienced this.
Old Nov 2, 2015 | 09:38 AM
Egodriver71's Avatar
I use it here and there. More for downshifts than upshifts.
To me it's useless for upshifts since it will not upshift unless you have met the program requirements or it will upshift anyway if you get to the revlimiter.
I'd love to have 3 pedals, but I wanted a SRT6 more.
Old Jun 17, 2016 | 02:34 PM
TwiZtedCheese's Avatar
Default Re: Auto-Stick Makes Up for Sticky Transmission
I'm pretty sure That's the automatic downhill low gear thing. Does it to me too and once I reach the bottom of the hill I just floor it and make my passenger **** in my seat.
Old Jun 18, 2016 | 06:30 AM
sirharper's Avatar
Autostick in my Crossfire definately behaves differently than my other Mopars. I tend to use it less often with the Crossie than I do with my Hemi's.
Old Jun 20, 2016 | 06:30 PM
Mike-in-Orange's Avatar
I have a 6 speed manual in my 2005 Roadster and love it. My 2004 Coupe has an automatic and I rarely use the Autostick feature simply because it's just too damn slow when shifting. About the only time I use it is to downshift to pass as these cars just don't want to downshift with the throttle unless you mat the pedal to the floor, and I don't always need that.
Maybe I'm a bit spoiled because my job affords me the opportunity to drive a lot of really, REALLY nice cars with truly modern automatic transmissions. The kind that will shift NOW as soon as you touch the paddle shifter behind the wheel, even rev matching on downshifts. Once you drive something that reacts like that, you'll never want to touch the Autostick again. This isn't my first Chrysler product with an Autostick, either, and I almost never used it in the other cars for the same reason.
pioneer4x4
Sep 18, 2023 11:49 AM
grip grip
Other Cars Etc
Sep 26, 2015 09:52 PM
kuratsunade
Aug 12, 2015 10:37 PM
maxcichon
Jul 31, 2015 11:34 AM
pioneer4x4
Jul 21, 2015 10:35 PM
