Hose
Old Feb 9, 2010 | 11:57 PM
murtazanooruddin's Avatar
Question Hose
what is this hose for and how do i replace this? is there a simple way to replace it any help would be appreciated thanks!
Old Feb 10, 2010 | 12:00 AM
tighed1's Avatar
Default Re: Hose
Is that the PCV hose?
Goes from the valve cover to the air intake?
Gonna be hard to find the exact replace part. May just have to go to the parts store a get a piece that will work in its place.
Old Feb 10, 2010 | 09:42 AM
32krazy!'s Avatar
Default Re: Hose
maybe you can just trimm the torn section off then use a hose clamp to keep it in place
Old Feb 10, 2010 | 03:38 PM
MikeR's Avatar
Default Re: Hose
DJ, You are correct. That is a PCV hose. I would just go to the parts store and get a new length of hose, cut it to fit and install. Trimming off the bad part would be even easier if the hose is long enough.....
Old Feb 10, 2010 | 06:25 PM
CRM's Avatar
CRM
Default Re: Hose
If you will follow the hose around, you will eventually see a part number embossed on it. Not a tough job at all.All just push on connections.
Part number should be 112 018 02 82 or 112 018 04 82 depending on the side., but it will be on the old one.
waldig
Sep 2, 2015 11:02 AM
glover
U.K.
Aug 24, 2015 08:03 AM
glover
Aug 23, 2015 05:07 PM
ala_xfire
Aug 16, 2015 09:45 PM
crymar
Jul 17, 2015 08:46 AM
