Engine Cover
Old Apr 27, 2010 | 05:50 PM
Don Hiltz's Avatar
Default Engine Cover
I've been looking for a new engine cover since mine was broken. E Bay has a used Mercedes unit which purportedly will fit an '03-'05 CLK 320.
Isn't that the basis for our cars? The picture looks good, but there's no opening for the oil intake
What think you??????
Don
Old Apr 27, 2010 | 06:34 PM
JHM2K's Avatar
Default Re: Engine Cover
That will work just fine. It's basically the same intake use on mine, and it's also used on C430 if I'm not mistaken. Mercedes part #1120901101
The front shroud is another separate part; Mercedes part #1120100467
I bought mine brand new on parts.com for ~$100 shipped. The stealerships demand $170. At least my local one did...
Pics are in my gallery. Mine has been painted though; OEM is flat plastic.
Old Apr 27, 2010 | 06:58 PM
Don Hiltz's Avatar
Sent you a PM
Thanks,
Don
Old Apr 27, 2010 | 07:05 PM
xodus52's Avatar
Very slick job on the engine cover. Where did you get the rigid looking intake tubes?
Old Apr 27, 2010 | 07:16 PM
JHM2K's Avatar
Thanks man!
The tubes are from TVT... ~$100 for the pair. I shot 'em with white to match the airbox. They are 3" aluminum and fit like a glove. Very little heat soak.
Old Apr 27, 2010 | 07:22 PM
xodus52's Avatar
Thanks man!
Very cool. What type of paint did you use on them?
Old Apr 27, 2010 | 07:33 PM
Don, which cover did you break? If it is the front part, I have an extra, I probably will never use again....they make great wall ornaments in the garage...
JHM2K's Avatar
I used Valspar for the plastic (special type that bonds with raw plastic, negating the need for primer) and I used the remainder on the tubes because I wanted them to match perfectly. It came out very well, and the heat under the engine bay "cured" the paint. Now it's hard as a brick and no problems with smudges.
Paint is at Lowes for $7 a can.
PNA
Nov 12, 2020 04:44 PM
reiji
Oct 15, 2015 10:50 PM
Mopar or No Car
Aug 11, 2015 08:11 AM
KDW4Him
Jul 31, 2015 10:21 AM
cjfine
Jul 20, 2015 11:58 PM
