Brake Light
Old Jun 11, 2010 | 09:47 AM
lmrzljak's Avatar
Default Brake Light
For some reason, the red "Brake" light keeps flickering constantly. It never stays on but it'll go crazy and go on and off like a thousand times in a minute. I tried pulling over and putting up and down my e-break that doesn't seem to help. It's not affecting how the car drives, it's just extremely annoying!!! It's been a week now that this has been going on, hopefully this isn't the end of my electrical system! bah! Anyone ever had a similar problem?
gracias!
Old Jun 11, 2010 | 09:57 AM
Blast Chamber's Avatar
Default Re: Brake Light
This is just a stab in the dark, but the brake pads have wear sensors on them. I'm not sure if these sensors cause the "Brake" light to illuminate on the dash, but if the pads are worn down that may be a possibility?
Old Jun 11, 2010 | 10:01 AM
Cody M's Avatar
try disconnecting the battery for a while and see what that gets you. if it still does it then it could be a faulty switch inside the master cylinder
Old Jun 11, 2010 | 10:06 AM
yerdsyerds's Avatar
could also be a loose or dirty connection anywhere in the wiring for the system(s) that activate the brake light. Happened to me with the oil level sensor. Dirty connector - it was corroding, and they cleaned it up and POOF! better.
Old Jun 11, 2010 | 12:54 PM
maxcichon's Avatar
Edit.
Sounds like an intermittent switch/ground.
Old Jun 11, 2010 | 02:08 PM
lmrzljak's Avatar
Edit.
my ground from my amp is a little loose, comes in an out sometimes... you think that could cause it lol?
Old Jun 11, 2010 | 02:30 PM
maxcichon's Avatar
Maybe. Hold it up to your computer monitor so I can get a better look!
Old Jun 11, 2010 | 02:34 PM
MikeR's Avatar
nope.... that looks fine to me.....
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
xfClifford
27
Nov 10, 2015 10:08 PM
PNA
Jul 27, 2015 12:28 PM
Blackout317
Jul 7, 2015 08:38 PM
