low tire pressure light on?
but no low tire pressure. has this happened to anyone else? how did the dealer fix the problem? thanks!
Yes, the same thing did happen to me - after the weather suddenly turned cooler. I just topped off each tire with a few pounds of air - even though they all read correctly - and it "fixed" the problem. I sometimes question the accuracy of the guages we use. I have 3 or 4 and they all differ by a pound or 2. My most accurate seems to be the one I bought for our travel trailer. It's got a higher pressure reading. My other ones are only good for 50 pounds and this one can read up to 80.
i adjusted the air pressure (was high) down to 36 psi and the light still remains on :?
any other ideas? where is our crossfire tech?
I'm one of those people keeping the car in the garage all winter, and yesterday was nice, so I brought her out. The tires were low, and after re-inflating them to the proper psi, I had to turn the key off and then back on again in order for the low pressure light to turn off.
Originally Posted by houstondan
i wonder if it's a "low" pressure sensor or if it's a pressure "deviance" sensor? would it also activate if the pressure is too high??
dan
dan
I religiously check my pressure every couple of weeks and keep it at 32/33. It's the most **** I've ever been in my life.
Last week I caught what I thought might be a problem with one of my tires - and turned out to be the shaft of a screwdriver banging around! I managed to catch it before any real damage was done. So, thanks again, as you might have saved me from having to start the fight of finding a new tire!
For everyone else: "check the tires... check the tires..." :wink:
Originally Posted by shawd
Talk about ****, I just bought a tire gage and my own air compressor. The tires are so thin I'm almost afaid to hit a bump. Are the tires tougher than they look ?
the tires seem to be able to take hard use ok but you will get wheel damage a lot easier. try to keep the curb-jumping down to a minimum. :lol:
dan
dan
dan
:shock: :shock: :lol:
dan
