Spark Plugs and Wires for Performance Inc.?
Old Aug 29, 2010 | 11:32 PM
tje275's Avatar
Default Spark Plugs and Wires for Performance Inc.?
Just bought the X-Fire 2 weeks ago and trying to replace some things that it seems like it needs Looking to get new Plugs and wires that will increase my performance. Anyone had any experience and would highly recommend a particular brand? Try doing the search function however didnt come up with any clear specific answers. Thanks for th help if you got it.
Old Aug 29, 2010 | 11:47 PM
Germany's Avatar
Default Re: Spark Plugs and Wires for Performance Inc.?
I have the NGK Spark Plugs and the Magnecor wires. I would recommend them, because you notice a slight difference in acceleration and throttle response. They are expensive, but they also look good compared to the stock ones. I would really recommend them. Once they are installed, they will be worth the money
Old Aug 29, 2010 | 11:52 PM
tje275's Avatar
How much you think they run? Thanks for the info
Old Aug 30, 2010 | 12:34 AM
Germany's Avatar
I heard some people say 10hp gain, but I def. dont believe in that.
Check with Rob from Needswings. He's got them at a good price...
Performance auto parts & aftermarket auto accessories for your car, specializing SRT4, Crossfire SRT6, SLK32, C32 AMG, VR-4
Old Aug 30, 2010 | 08:13 AM
OKC-XFR's Avatar
+1 on the NGK iridium plugs and Magnecor wires.
I am very pleased with the ones I put in my car. Go with the one step colder plugs on the site that Germany listed - you won't be disappointed.
Old Aug 30, 2010 | 09:10 AM
ZAHANMA's Avatar
+2 on the NGK + Magnecor combo. Plugs will run you 7-8 each and the wires around 150 for a set. If you install both yourself then both could be done for <250 in my opinion.
Old Aug 30, 2010 | 12:17 PM
Goldwing's Avatar
Keep in mind there are 12 plugs on these babies. I'm also skeptical that just plugs and wires will increase hp by 10. The manufacturers usually optimize that combination and unless yours are real worn or in poor shape, I cannot believe that much difference. But if they look cool and you need (or want) them, knock yourself out. PS - Same for K&N. I noticed a tad better gas mileage but no noticeable performance increase. The risk is dirtier air but the benefit is a "forever" air filter.
Old Aug 31, 2010 | 12:37 AM
tje275's Avatar
Should I get 1 heat range colder or should I just get the stock ones. Im not planning on doing any other tuning or modifications, The stock ones and one heat range colder are the same price, wats the difference?
Old Aug 31, 2010 | 12:49 AM
tje275's Avatar
My Crossfire has 80,000 miles on it as well if that matters, dont believe they've ever been changed from the stock ones they came with.
Old Aug 31, 2010 | 01:03 AM
Germany's Avatar
Depends how many modifications you have. If you car is stock and you want to keep like that, the normal ones are good enough. If you're planning to make mods in the near future, I would recommend the 1 heat colder ones. Reminds me, I need to change mine ^^
Old Sep 2, 2010 | 12:27 AM
tje275's Avatar
But if i get the one heat colder ones, they should be fine as well right? Even if I end up not doing any other mods, but if i do I want them just in case.
Old Sep 2, 2010 | 02:07 AM
Germany's Avatar
I'm not a spark plug guru, but I think it wouldent be too bad.
If ur gonna enjoy changing the cables and spark plugs on an XF by yourself, be patient. Its a pure pain in the a**, but worth it at the end. Just need the right tools.
Dont you need to Torque the spark plugs to certain level? Anyone?--------
Old Oct 17, 2010 | 02:29 PM
deltacrossfirebob's Avatar
what did you go with??
how did it work???
thanks
Old Oct 17, 2010 | 04:56 PM
shapeshifter309's Avatar
Torque specs for the spark plugs are in the manual.
Old Oct 17, 2010 | 05:35 PM
32krazy!'s Avatar
dont forget to apply a thin layer of antiseize to the threads of the plugs to prevent galling of the threads in the aluminium heads. torque specs are critical as well . you can also clock the plugs to ensure a complete burn. takes time but worth it
Old Oct 18, 2010 | 10:01 AM
Make sure their gapped correctly as well.
Old Oct 18, 2010 | 10:32 AM
NeedsWings's Avatar
the trick to easy spark plugs swapping....
remove the single bolt for each motor mount and jack up one side of the motor at a time with a jack and block of wood, just dont forget to put the motor mount bolts back in
Old Oct 21, 2010 | 09:26 PM
tje275's Avatar
Put the plugs and wires that I bought from Needswings in about 3 weeks ago, Was a real pain in the ***, didnt know about that trick with jacking up one side at a time, but the crossfire has been running smooth since. Thanks for all the help whoever contributed to the thread
Old Nov 11, 2010 | 01:12 PM
jdokan's Avatar
This is an AWESOME trick...will try it a s soon as my order for plugs & wires comes in from you....Which will be ordered tonight.....
thanks,
Jeff,
Old Nov 16, 2010 | 03:40 PM
dinasrt's Avatar
Good advice here about antisieze on the plug threads. But I'll have to say that IMHO clocking the plugs is a complete waste of time. Is there one person on this forum that could tell you exactly(instructions) how to "clock the plugs" in our Crossfires? I mean 12 plugs oriented which direction(exactly)? They're not all going to be the same. It's hard enough to change our plugs normally. What a nightmare it would be to do this. Even if you did this procedure, my bet is that the gain is insignificant to undetectable; at least in our vehicles. If there is one Crossfire owner or Mechanic that has actually done this(on an M112), and realized any gain, I would love to hear about it.
