odometer reset
Old Apr 2, 2004 | 03:43 PM
The King's Avatar
Default odometer reset
Love my crossfire however unable to reset the trip odometer, is this a common problem ?
Old Apr 2, 2004 | 04:05 PM
WesMichaels's Avatar
Default
Are you holding the reset button in for a few seconds? It takes a few.
Old Apr 2, 2004 | 04:06 PM
DFWSBR's Avatar
Default
Start the vehicle, once it has been running for say, 30 seconds.
Hold down the left selector on the dash for about 7 seconds.
It should reset to ZERO
Old Apr 2, 2004 | 04:26 PM
The King's Avatar
Default
Tried all that , window goes blank , wrench appears than disapears and milage does not change
Old Apr 2, 2004 | 04:32 PM
DFWSBR's Avatar
Default
Hmm.. I'd take it into the dealer.
Before doing that, see your service manual. Since it isn't showing your service mileage either, maybe you want to reset that as well.
Old Apr 2, 2004 | 05:09 PM
The King's Avatar
Default
service mileage appears, I hate to think that the dealer would go in to the dash , then I might have rattles later on , not being able to reset my odometer is no big deal compared to a devirginized dash
Old Apr 2, 2004 | 05:12 PM
The King's Avatar
Default
P.s. how do I post all that cool stuff on the bottom like color of car and transmission
Old Apr 2, 2004 | 05:25 PM
Uncle_Al's Avatar
Default
The top of the screen lets you select profile. Then fill out your location & signature. Click the Always Attach button and you are in.
Old Apr 2, 2004 | 05:35 PM
The King's Avatar
Default
Thanks Uncle Al
Old Apr 2, 2004 | 09:04 PM
Steve in SoCal's Avatar
Default
I had the same problem, resolution is to replace the instrument cluster. I have no rattles from this procedure, but the dealer will have to know how to set the correct mileage into the odometer (it will be reset to zero after the instrument cluster is replaced). The problem I ended up with is that resetting the odometer messed up the service indicator. Apparently the service computer thinks all those miles that the dealer manually loads happened without any load on the engine and the service interval starts showing up as 10,000 miles. My dealer says the fix is going to require a software patch from DC.................
northwest_crossfire
May 30, 2016 05:19 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
MickeyNasty
Sep 6, 2015 08:29 PM
