CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Crossfire Coupe (https://www.crossfireforum.org/forum/crossfire-coupe/)
-   -   Please help me remove alternator/generator I'm such a novice (https://www.crossfireforum.org/forum/crossfire-coupe/45272-please-help-me-remove-alternator-generator-im-such-novice.html)
mp3wizard Sep 18, 2010 09:41 AM
Guys im trying to remove my alternator, I've had a good look around the forum, Im following this guide on page 27-28
http://homepage.mac.com/gregmeach/XF...-EngineSys.pdf
Basically so far I have loosened bolt 2 on the picture and It's not completely off, just sticking out, not sure if i need to remove it completely?
Basically i'm struggling to figure out how to remove the accessory belt? Is it just brute force? as I've yanked it really hard a few times and it doesn't seem to be able to move at all....
I assume once I get the belt off I will then be able to wiggle the generator about and disconnect/remove it?
Please help, I know nothing about cars, Just trying to save on garage bills....
I have a new alternator coming as this one has failed according to the garage...
I also need to replace a fuse as it's currently not cranking, its just clicking... but I guess I'll come to that later
onehundred80 Sep 18, 2010 10:58 AM
Re: Please help me remove alternator/generator I'm such a novice
To remove the belt you have to lock the belt tensioner and your pdf says see page 7-45.
You must not remove the alternator with the belt under spring pressure.:( That's dangerous.
mp3wizard Sep 18, 2010 11:30 AM
6 Attachment(s)
Guys... think I've been loosening the wrong bolt lol...
Please see these pictures... basically i've been loosening the bolt with the wrench on it anti clockwise...
After seeing another post on the forum, I'm led to beleive that I should of actually been loosening the nut with the red circle... is that right?
mp3wizard Sep 18, 2010 11:41 AM
Actually comparing it to the picture on the left, the bolt would be somewhere around where the black arrow is pointing, is that correct?
thanks
MikeR Sep 18, 2010 11:56 AM
sorry to tell you.... but your on the WRONG side of the engine.... the alternator is on the passenger side..
PLEASE tighten any bolts you have loosened back to spec...
Go here and download the 2004 Crossfire Service Manual..
https://www.crossfireforum.org/forum...ollection.html
then go to Section 7, Cooling, page 7-42... this will show you the drawing of how the belt wraps and which pulley is which.... note #7 (tensioner) and #5 (alternator/generator)..... read down a couple of pages and it will show you how to take the fan belt off..... then use your pdf file to remove the correct bolts on the alternator and disconnect the wiring....
IBLUBYU Sep 18, 2010 12:05 PM
From what I see, you are loosening a bolt on pulley #3. Pulley #7 is the belt tensioner, and that is the smaller pulley just to the left. On a non SRT engine there should be a bolt just down to the left of that pulley that needs to be loosened before the pulley can be adjusted to lessen tension on the belt. I have an SRT and this extra bolt is not on it, so I'm going from memory on this.
Someone with a N/A will hopefully chime in on this, to corroborate.
Edit: see that MIKE to the rescue ......
mp3wizard Sep 18, 2010 12:52 PM
thanks, yes i think i was loosening the power steering pump, i see now that the tensioner is next to it, I think i'll have to take the fan out as I really can't see what i should be doing...
IBLUBYU Sep 18, 2010 01:12 PM
Best done to see AND make it easier ....... Have Fun :)
onehundred80 Sep 18, 2010 01:22 PM
Here's the tensioner pulley and the nut you use to take the tension off the belt.
https://www.crossfireforum.org/forum...tml#post341784
You do not undo the nut it is a dummy, it is used as a leverage point.
mp3wizard Sep 19, 2010 05:47 AM
thanks chaps, I'm going to have a try today, so by just turning that nut a few times, it should make the belt more slack?
mp3wizard Sep 19, 2010 09:08 AM
Removed the fan, and can now see the nut, but i've got nothing that fits it... got loads of socket sets but nothing that will fit the nut without rounding if off... does anyone know what tool I should buy?
IBLUBYU Sep 19, 2010 09:22 AM
Can't tell you for sure .... but it's got to be metric NOT sae .......
32krazy! Sep 19, 2010 09:48 AM
most likley its a torx bit needed to loosen the tensioner. it works as a fulcrum and wont loosen the nut itself. when counter clockwise tension is applied the whole pulley moves and provides enough slack to slip the belt off. then slowly let the pulley move clockwise until it rests or you will find your arm stuck at the bottom of the engine bay!!
James1549 Sep 19, 2010 10:32 AM
First I will give you credit for trying. But trying to remove an alternator without knowing what it even looks like is a clue you may need some help.
To loosen the tensioner, you need a 17mm deep socket on the 3/8" ratchet. The longer the ratchet, the better leverage. See pic. Using the casted bolt (seen in the mirror), twist the tensioner to release the belt. Once the belt is off, then you can remove the two alternator mounting bolts. I assume there are only 2, that is all I see looking at my car. Good luck. James
https://www.crossfireforum.org/galle...um/TENSION.jpg
James1549 Sep 19, 2010 10:37 AM
PS I don't see any need to remove any fan. You do have a NA?
Here are some quick pix of a spare tensioner I had on the shelf.
This is what you need to pivot or release the tension on the belt:
https://www.crossfireforum.org/galle...0/tension2.jpg
You only need to remove the pulley if the bearing would be bad, or you need access to one of the bolts to remove the entire assembly:
https://www.crossfireforum.org/galle...0/tension1.jpg
onehundred80 Sep 19, 2010 10:58 AM
I have got to admire your spirit, something like this is not a major job but if a person is doing something like this for the first time it can be a daunting task.
You must have metric tools, that is the first thing , Otherwise you will strip some metal off the hexagonal corners and some times that can be dangerous, such as when the wrench slips and you cut yourself or in this case a component under spring pressure is released unexpectedly. Keep your fingers away from that belt; don't let them caught between the belt and pulleys.
Page 7.46 shows the use of a 5mm diameter pin to hold the tensioner in a position against spring pressure. I would recommend the use of a 3/16" diameter drill.
If you lock the tensioner in this position you will have a much easier time removing and replacing the belt.
Pages 7.45 and 7.46 show all you neeed to know at this time, lock that tensioner and get the belt off that alternator.
Edit
You can see in James photo immediately above this post that the tensioner in the photo is in its relaxed position. The metal stop on the top half you can see is in a slot in the bottom half. Rotating the top half anti-clockwise would be against spring pressure and this is what you have to do to insert the 3/16 diameter pin. This pin will go through a hole in the top half and lock in a hole in the bottom half. It will stay there held by the spring pressure, the location where the two holes align will be almost at the extreme end of the travel of the top half, all the travel will be against spring pressure.
IBLUBYU Sep 19, 2010 11:22 AM
I'm sorry ... but I can't help chuckling a little ..... mp3wizard must, at this point, feel he's way over his head on this, and starting to take PROZAC .....
Please "mp3" don't take a crow bar and 8 pound sledge to it ....... hang in there ....;)
Besides .... if and when you get this done, you'll be more of an expert on it, then probably 95% of the rest of us.......
MikeR Sep 19, 2010 11:27 AM
^^^^^ agreed... do not get discouraged..changing the alternator is a pretty easy job... just be careful and take your time...;)
and as 180 said, use the right tools..you dont want to add more damage to the car or yourself....:(
mp3wizard Sep 20, 2010 04:21 PM
lol I wouldn't of attempted it but everyone on here said it was an easy job so i thought I can do that!
I'm going to give it another go in a few days (tools permitting) I'll let you know how it goes, hopefully i'll still have 2 arms!
Thanks again for the pics/guidance...
mp3wizard Sep 22, 2010 02:56 PM
17MM 3/8" DRIVE METRIC SOCKET FOR SET & RATCHET WRENCH on eBay (end time 03-Oct-10 18:49:26 BST)
guys is this definetly the right metric socket I need for the tensioner pulley, please confirm...
© 2026 MH Sub I, LLC dba Internet Brands
