Quick tire question, Please help ASAP!!!
Old Nov 5, 2010 | 04:57 PM
Musclefan21's Avatar
Question Quick tire question, Please help ASAP!!!
I just got a really good deal on a 255/50/19 tire and bought it. I just dropped the car to a tire shop to get them mounted. I know I have dropped my car 2" before and drove around without any rubbing issues and I think 255/50/19 isnt more than 2" taller than the 255/35/19s.
Please answer me if 255/50/19 will fit OK enough to get me through the winter.
Thanks.
Old Nov 5, 2010 | 05:01 PM
Default Re: Quick tire question, Please help ASAP!!!
Thanks.
just adding a little more sidewall....should be fine...
Old Nov 5, 2010 | 05:14 PM
Awesome! I had a slammed crossfire and I didnt have any rubbing issues. 255/50/19 is only 1,5" taller than 255/35/19. I just figured 1.5" taller tire shouldnt rub. I hope it is the case or else I just wasted 250 bucks
Old Nov 5, 2010 | 05:15 PM
Bladecutter's Avatar
255/35-19 has an overall diameter of 26".
255/50-19 has an overall diameter of 29.1".
These are specs I grabbed from tirerack from the Blizzak LM-60 spec sheet.
BC.
Old Nov 5, 2010 | 05:19 PM
MikeR's Avatar
^^^ that would be correct doing the simple math..... so it will lift you axel up 1.5" and fill your wheel well 1.5" more.....
Old Nov 5, 2010 | 05:25 PM
yeah i didnt think of that, 1.5" from the bottom and 1.5" from the top. basically, the car will be 1,5" higher at the back, tires are goiing to be 1,5" closer to the fenders. Would that be correct? If so, being 1,5" closer to fenders overall shouldnt create any rubbing correct? :S
Old Nov 5, 2010 | 05:34 PM
too big. dont buy anything taller than 255/40/10. :/
Old Nov 6, 2010 | 09:49 AM
Chris L.'s Avatar
You mean it didn't work?
Old Nov 6, 2010 | 12:19 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
This site has a graet tire size differentiation calculator.
As per this site: Tire size calculator
Using the sizes you posted: The speedometer will read 60MPH when you are actually travelling 66.9MPH
11.6% too slow.
Also, would a large variation between the front and rear tire sizes cause issues with the BAS/EAS system?
Old Nov 8, 2010 | 04:29 PM
Mike1118's Avatar
Sorry about your luck 21. I'm hope'n mine is a little better. I need to get a new tire now! I've got a hunk of metal in a rear tire. The only thing I found close is a pair of 275/45/19's that the tire store claims came off a Crossfire. I hope they fit, less than 300 miles on them and only 60 bucks a piece.
Old Nov 8, 2010 | 04:55 PM
Beaner's Avatar
Just make sure if they rub the store will take them back off and get your $ back
Old Nov 8, 2010 | 07:18 PM
Mike1118's Avatar
Smile Re: Quick tire question, Please help ASAP!!!
Good advice Beaner. I have an appt. for a test fit tomorrow. I hope they work out. I'm go'n to order 4 new Conti DSW's next week. I hope to keep these for spares for times just like this. I'm hope'n to be settled on my wheels by the time I order the new skins and have everything, along with the stabilazier shock all done at the same time.
Old Nov 9, 2010 | 04:48 PM
Mike1118's Avatar
Welp. 275/45/19's don't work nether. Anyways while sit'n in the wait'n room a guy ask me how I liked my car Turns out he has White roadster 6 speed sit'n in his garage. Later as I'm walk'n in to a store for something else a guy pulls up and asks how do I like my car. HE has a Blaze Red 6 speed set'n in his garage! I thins dat all the Crossfire 6 speeds are be'n held hostage in garages in central Ohio!
Old Nov 9, 2010 | 05:09 PM
Beaner's Avatar
I guess it is time to put on some dark clothing and mask and let these crossfires out one night!
xfClifford
Mar 3, 2021 04:52 PM
Xfirenewbie
U.K.
Aug 13, 2015 04:39 PM
Bayukbros
Jul 29, 2015 10:16 AM
Bifftws
Racing
Jul 28, 2015 05:31 PM
