Crossfire Block Heater
Old Feb 15, 2011 | 01:21 PM
Roy Mander's Avatar
Default Crossfire Block Heater
At the moment on Ebay are advertised Block Heaters for the Crossfire, apparently to screw into the block.
Has anyone bought and used one of these, and how and where do they fit.
Old Feb 15, 2011 | 07:57 PM
TomStratRT's Avatar
Default Re: Crossfire Block Heater
Also wondering that myself. Would love to have one if it's easy enough to install.
Old Feb 15, 2011 | 08:27 PM
I am familiar with the type that installs into a frost plug hole. I have, but never installed a type the fitted into a radiator return hose, this was a heat pump that used the warmed water to operate the pumping action. Clever but I could never be bothered to fit it.
Our engines warm up so quickly I wonder if they would do much good unless you lived in the far North.
Old Feb 15, 2011 | 10:42 PM
rcompart's Avatar
Stay away from these like aids. You mess with the block on this car and you're going to be wishing you were flexible enough to kick your own *ss.
Mercedes uses a coolant heater connected to the waterpump. If you want to add it, you'll need to order the following parts from Mercedes:
A 112 203 00 61 - Cooling-Water Preheater Housing
A 606 200 00 96 - Preheater
A 000 159 29 32 - Preheater Connecting Cable
A 006 997 75 48 - Seal Ring
A 210 501 53 82 - Hose Water Pump Heater Unit
A 202 501 69 82 - Hose Between Water Pump Heater Unit And Radiator Bottom
N 000000 002775 - Clamp Water Pump Heater Unit (qty. 2)
N 000000 001117 - Hexalobular Bolt Housing To Timing Case Cover M6X23 (qty. 2)
It's about $300 in parts but if you're dead set on adding a block heater to this car, this is the right way to do it. After seeing the fiasco that happened with the throttle bodies, I figured I'd post this so at least the correct information is here on the forum.
BTW, if your car is originally from Canada, you only need the Preheater Connecting Cable as the rest of the parts are already in your car.
Good luck and take care
Old Feb 15, 2011 | 11:00 PM
So that means the dollar exchange rate, the DTRL's and this heater must Total $9,000 Can.
Boy that is good to know.
Old Feb 15, 2011 | 11:04 PM
rcompart's Avatar
Well don't forget the complimentary "Eh"! That's gotta account for something.
Old Feb 15, 2011 | 11:10 PM
You've been around Beaner too long.
Normally we just light a fire under the engine and toast some wieners while we wait. So they put in a heater to save the plastic engine pan.
Old Feb 15, 2011 | 11:25 PM
rcompart's Avatar
I grew up in Minnesota. We say eh too, but mostly after a question. Should have see Steve's face the first time we spoke in person. Priceless!!!
Old Feb 16, 2011 | 12:07 AM
We have the heater housing installed and where the heater goes is a blank brass threaded fitting. This is removed and the heater threaded in its place, the new part has the terminals on it. So Canadians need the cable and the heater.
Edit
I think Rudy may be correct - again, The brass fitting has a plastic cover on it and that is probably protecting the terminals. I cannot get a grip on it to remove it to make it definite, but there would be no need for the plastic cap otherwise.
That Rudy is always correct, I hate guys like that.
They probably want a fortune for the heater and cable at the stealership, but it is around $35 on line.
On a Benz forum a Canadian dealer wanted $317 for the cable. Another Canadian dealer wanted $600 plus $200 labor for a heater kit fitted.
The heaterkit.
Block Heater
I came from England and we say 'Eh' as well.
Old Feb 16, 2011 | 12:23 AM
On a Benz forum a Canadian dealer wanted $317 for the cable and presumably the heater. Another Canadian dealer wanted $600 plus $200 labor for a heater kit fitted.
I come from a little burg in NE MO calle "Kahoka." We say "eh"all the time. I don't think it's patented.
Seems I have been sayin' "eh" a lot lately. For example, earlier Crumpy says there is sumthin' wrong with my hearing. I say "eh?" I don't wear any earing.
Nite guys.
roadster with a stick
Old Feb 16, 2011 | 04:05 PM
Kodebuster's Avatar
Somebody help me, this is not for keeping the block warm in (very) cold climates when the engine is shut down, rather it's for allowing the engine to warm quickly...???
Can someone elaborate...
Thanx...
Disregard, I just saw the pix with the 3-prong house plug so I'll assume it's for warming a shut down engine...
Old Feb 16, 2011 | 11:37 PM
So if I am looking at this correctly, the US cars have a 1 piece lower radiator hose, where as the CAN cars have 2 piece hose with the heater housing in between? Very interesting.
James
Frankenmerc
20
Dec 13, 2025 11:51 PM
foxy1305
U.K.
Jun 22, 2015 11:17 AM
WindRestrictor
Jun 16, 2015 12:18 PM
MJPowers
Jun 8, 2015 02:34 AM
WindRestrictor
Jun 1, 2015 02:31 PM
