I'm downgrading my rear tires to 18 inches on 225.40.18
Old Apr 3, 2011 | 08:39 PM
bionicdriver's Avatar
Default I'm downgrading my rear tires to 18 inches on 225.40.18
From 225/40/18 on all 4 tires Achilles ATR Sport (Summer) tires on Speedy Illusion Rims check out the link im ordering today.
speedy illusion rims and tires packages. speedy illusion black w/ red lip wheels and tires packages at WheelsNext.com
Old Apr 3, 2011 | 10:12 PM
Squirrel Crusher's Avatar
Default Re: Im downgrading my rear tires to 18 inches on 225.40/18
Not into black wheels,but those could change my mind. Looks Good! Squirrel Crusher
Old Apr 3, 2011 | 10:17 PM
Jesus_Christler's Avatar
The stripes match your interior
How much do the rims weigh?
Old Apr 4, 2011 | 08:40 AM
Chris L.'s Avatar
Default Re: I'm downgrading my rear tires to 18 inches on 225.40.18
[quote=bionicdriver]From 225/40/18 on all 4 tires Achilles ATR Sport (Summer) tires on Speedy Illusion Rims check out the link im ordering today.
Those are All-Season tires, not summer tires. I've put almost 20,000 miles on a set of fronts & have been very happy. Looks like I'll get about 40,000 out of them. $67 at Onlinetires.com.
Old Apr 4, 2011 | 09:06 AM
Kane's Avatar
Banned
Could I ask why you want to do this?
The Crossfire is know for its classic 18/19 'staggered' look, and I am curious as to how it will appear all laid out flat. Show us pics when you're done.
Old Apr 4, 2011 | 09:12 AM
mdaniels4's Avatar
They are a pretty good deal. I saw that they had 235-40/18 on the fronts, and 245-35/19 for the rears. That's only a slight drop from the 255/35 that's OEM, so I wonder how far off the speedo would be with that sizing. Even with shipping we're talking about installed 800 for DWS's vs about 500 max for these.
Old Apr 4, 2011 | 11:29 AM
Rims not my taste, but to each their own.
Pics when installed, please
Old Apr 4, 2011 | 11:52 AM
mdaniels4's Avatar
Wheels:
FWIW, if you did stock in the front, and the 245/35-19's in the rear, the sidewalls of the rear would only be .10" shorter than the front's, 3.5 compared to 3.4", and even though the overall tire would be just a tad shorter, not even noticeable, the speedo is only 1/2 MPH off. This seems to me to be a great tradeoff in pricing/vs overall value. Just wish I knew if Achilles were good overall tires. All seasons though?
Wheel 1 OEM
Wheel 2
Wheel size19x9 ET 2219x9 ET 22 BackSpace149 mm (5.8'')149 mm (5.8'')Typical Weight~ 33 lbs / 15 kg~ 33 lbs / 15 kgTires:Tire 1Tire 2Tire size255/35-19245/35-19Section width255 mm (10'')245 mm (9.6'')Sidewall89 mm (3.5'')86 mm (3.4'')Tire diameter661 mm (26'')655 mm (25.8'')
6 mm (0.9%) shorter.Rim sizes19x7.5 to 19x9.519x7.5 to 19x9Circumference2076 mm (81.7'')2057 mm (81'')Revs per mile775.4782.5
SpeedometerAssuming that this is OEM tire and speedometer readings are correct When speedometer reads 60mph (96.6km/h) actual speed will be 59.5mph (95.8km/h): 0.8% slower.Typical Weight~ 24 lbs / 11 kg~ 23 lbs / 10 kgWheel+Tire Weight~ 57 lbs / 26 kg~ 56 lbs / 25 kgClearance:Package 1Package 2SuspensionAssuming that this is OEM wheel/tire and there is no any problems with clearance on both sides 100% clear (leaves even more room than OEM) Fenders100% clear (leaves even more room than OEM)Wheelwells100% clear (leaves even more room than OEM)
Old Apr 4, 2011 | 12:40 PM
Chris L.'s Avatar
Like I said, after almost 20,000 miles on my 07 6 spd XF.....the Achilles (on the front) still have slightly deeper tread depth (about 6/32nds) left than the OEM fronts on my wife's 08 automatic XF & her car only has 10,400 miles on it.
Both cars are wearing evenly across their tires. I've had them up to 120 mph & driven thru 6-8 in snows....I'm still alive!!
Old Apr 4, 2011 | 12:56 PM
mdaniels4's Avatar
How's the tire noise and the wandering on them? My conti-oem's are just past 27K and the fronts are yet pretty good, the rears need to be replaced, so I think I got pretty good wear out of them. their noise levels in the rear though now are getting more annoying. The reviews online were poor for noise, just wondering what you thought. handling in wet was marginal too, but you may have a different perspective. Would like to hear from you on those points.
Old Apr 4, 2011 | 01:08 PM
Chris L.'s Avatar
Well, on my 07 (I guess it says something about the way I drive) (both cars were purchased new)...when it was just shy of a year old (17,000 on the odometer) the front OEM Contis had slipped belts....I had to replace them STAT locally....the tires I replaced them with became VERY noisy ....so when the odometer had about 41,000 miles on it was when I installed theses ATRs.....to this day they still quieter that the originals & first replacements.
Wife's car is quieter (OEMS)....but then I have Blizzaks on the rear of mine ....got those super cheap & have put 11,000 on them & they still have 8/32nds left !!!!!
So happy with the combo....I have a second set of both in the basement.
Old Apr 10, 2011 | 02:10 AM
jmk41's Avatar
stock tire size for the back is 255 35 R19 as long as you go with a 2## 40 r18 its essentially the same size and will cause no speedo errors
MAXIMUM
Aug 4, 2015 11:04 PM
waldig
Jul 30, 2015 07:39 PM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
Buchacho
Jul 9, 2015 04:13 PM
