Flat Tire!!!
Old Apr 22, 2011 | 03:12 PM
markenseth's Avatar
Default Flat Tire!!!
i know this sounds stupid but i have a flat front tire and i'm trying to change it but i can't get the darn tire off. i jacked it up and took the lugs off but now i can't pull it off. does anybody know if there is a lock or something that i don't know about.
Old Apr 22, 2011 | 03:20 PM
scar426's Avatar
Default Re: Flat Tire!!!
Nope, try giving it a kick. Probably just corroded to the hub if it hasn't been off in a while.
Old Apr 22, 2011 | 03:23 PM
markenseth's Avatar
wow...just kicked the crap out of it and it came off! i'm so stupid! thx man!!!
Old Apr 22, 2011 | 04:10 PM
Goldwing's Avatar
I remove my rims once a year for a good cleaning. I put a little heavy lube grease (you can also use wheel beating grease) around the hub/spindle to keep them from rusting together. I have never had a problem removing wheels.
Old Apr 22, 2011 | 05:12 PM
Really good advice & preventive maintenance.
Old Apr 22, 2011 | 06:24 PM
Blast Chamber's Avatar
Speaking of corrosion, just wait until you need to remove the brake rotors someday. I installed Rotex pads last year and pulled the rotors to have them turned. One of the rotors was rusted to the flange and I had a heck of a time removing it, and this was on a car that had only 10k miles at the time.
I used never-seize on the mating surfaces when I put the rotors back on to hopefully make things easier next time. I also use a light coating of never-seize on the mounting flanges of all my aluminum wheels. It really seems to help.
Old Apr 23, 2011 | 07:28 AM
scar426's Avatar
Great, no worries. Sometimes you just gotta get physical with a b*&%h, jk lol
Old Apr 24, 2011 | 05:17 AM
crossfirefun's Avatar
Make sure you torque the wheels to the correct poundage. Over torquing causes stripped studs or brake problems.
Old Apr 24, 2011 | 07:03 AM
BTW : depending on the source, the correct number is 82 or 85 foot/pounds .......
Old Apr 25, 2011 | 11:25 AM
Gandalfthgrey's Avatar
Unhappy Re: Flat Tire!!!
Most torque specifications are for dry/non-lubricated threads. Lubrication will allow the nut/bolt to be stretched further at a lower torque which may yield a broken bolt/screw before reaching stated torque.
Old Apr 25, 2011 | 11:42 AM
maxcichon's Avatar
Absolutely correct.
TerryR
Dec 13, 2019 03:27 PM
Mackel
Sep 29, 2015 02:41 PM
maxcichon
Sep 25, 2015 02:55 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
Den656
Sep 23, 2015 12:27 PM
