crooked glove boxes...
Old May 19, 2004 | 09:14 AM
drunkiq's Avatar
Default crooked glove boxes...
One of the first things I noticed that was wrong with my car was that the glove box is crooked and down on the left side. I have been looking at some pics here of everyones cars and noticed I may not be the only one. Even one of the pics on edmunds has a crooked one.
When the dealer looked at mine they where unable to adjust it. None of the other cars on the lot where like this and they have been trying to work with corporate to order the correct replacment part for the glove box. I am not sure if it is not molded correctly or not.
-marc
Old May 19, 2004 | 11:19 AM
xfirejunky's Avatar
Default Re: crooked glove boxes...
-marc
I had a crooked glove bow and fixed it myself. I saw so many pictures of Crossfires that were straight that I finally got Pissed and just did it myself. The first thing you should check is, see if the box moves when you push on it. If it does then you can adjust it a little and it might straighten yours out. If there is a little play in the box, loosen up the screw under the latch and move the latch towards the firewall. If you move it too far the box wouldn't engage and will keep onpening. I just moved it a little and it made all the difference. I think the screw was a torx but don't quote me on that.
Old May 19, 2004 | 11:33 AM
drunkiq's Avatar
Default
mine is crooked like Cyrils is:
I can push it up on the left side and it aligns up. The dealer tried adjusting all the screws that hold it in but never the latch it hooks to. I will take a look at it tonight and see if i can straighten it out.
Thanks!!!
-marc
Old May 19, 2004 | 01:49 PM
Cyril Baldwin's Avatar
Default
What causes mine to be crooked is from the cell phone holder tightening out the clearance in the upper left side area.
Old May 19, 2004 | 04:16 PM
drunkiq's Avatar
Default
great - so after I fix it, then it will be crooked when I put the cell phone holder in this weekend... :cry:
-marc
Old May 19, 2004 | 04:20 PM
drunkiq's Avatar
Default
hang on - Mightyjlr has it mounted on his car and his glove box is straight...
I will mess with it when the holder comes in...
-marc
Old May 20, 2004 | 09:06 PM
drunkiq's Avatar
Default
Xfirejunky,
That seemed to work!!
You are correct if you push it all the way back then it will not latch. You have to bring it just the smallest amout foward.
The other trick if figured out was to twist the latch to the side (it won't move much) as if you are trying to make it point to the passanger door. If it is centered or pushed towards the drivers door then it will not line up either.
Thanks for the help!
-marc
p.s. I guess I should tell my dealer about it... :wink:
Old May 20, 2004 | 10:35 PM
Default
I think mightyjlr drilled another hole to bring the cell holder higher. If you compare the distance of his cell holder from the top with mine...mightyjlr's is higher.
I'll try if it'll align better by bringing the cell holder higher with a new hole.
Old May 21, 2004 | 07:31 AM
drunkiq's Avatar
Default
I have not received my holder yet but will mess with it once I get it. I also noticed that mightyjlr even has a wire running into his glovebox. If I have to drill a hole than so be it.
also where did you get the silver univeral cell phone holder? All I have seen is black. I will most likley paint my bracket like yours too.
Thanks!
-marc
Old Jun 14, 2004 | 01:46 PM
drunkiq's Avatar
Default
The dealer replaced my glovebox today...
Now it looks like the one Mightyjlr has with my phone adaptor in it. Before it was only crooked when the cellphone mount was on after I tweaked it.
-marc
Old Jun 14, 2004 | 06:41 PM
drunkiq's Avatar
Default
Here is a crummy phone camera picture of my glovebox since it has been replaced (ingore the car cover on the hood):
Old Aug 11, 2004 | 10:07 PM
CrossfireCrush's Avatar
Default
Hey Drunkiq,
Where did you get that iPod setup? I saw another pic on this post farther up where it was attached to the cig lighter output, but that wouldn't work for me with my manual. Any info would be appreciated. Thanks! 8)
Old Aug 11, 2004 | 10:49 PM
drunkiq's Avatar
Default
it's a cell phone holder....
Old Aug 11, 2004 | 10:55 PM
Default
Thanks. I've never used one of those cell phone holders or even seen one outside of a photo which is why it wasn't obvious. :roll:
Old Aug 11, 2004 | 11:21 PM
VegasCrossfire's Avatar
Default
There are a few of us who use that cell phone holder as our GPS holder. It works great! :wink:
Mackel
Oct 16, 2015 09:03 AM
toob
Sep 26, 2015 11:44 AM
user 8202
Canada
Sep 1, 2015 11:43 AM
Mopar or No Car
Aug 11, 2015 08:11 AM
tom2112
Jul 8, 2015 08:13 PM
