Rough Idle
Old Sep 16, 2011 | 11:37 PM
Hyperman's Avatar
Default Rough Idle
Starting a new thread. Purchased a 2004 coupe in May. Car has rough idle at stoplights.
Here is what I have done so far:
Removed and cleaned MAF
Removed and cleaned throttle body
New K&N filters plus cleaned housing and air ducts
New plugs
New fuel filter
Ran through 2 bottles of Techron injector cleaner
Oil and Filter
Also had my mechanic check for vacuum leaks
No CEL and no codes
Any other thoughts?
Old Sep 18, 2011 | 09:10 PM
jerry rosewicz's Avatar
Default Re: Rough Idle
Could an ignition wire be bad (not sure if Crossfires even have wires ). Did anyone run a compression check before changing plugs? Everything you did seems like it should have smoothed out the idle.
Old Sep 19, 2011 | 08:23 AM
How rough is it? and is your mechanic a Merc specialist?
cdcrone123
15
Nov 10, 2022 10:47 AM
crossfireusa
Oct 28, 2015 12:03 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
SRTFAN
Aug 27, 2015 01:25 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
