valve gasket - fuel line
Old Nov 11, 2011 | 08:41 AM
sleepydo's Avatar
Default valve gasket - fuel line
when removing driver side valve cover do you need to disconnect fuel line? if so, how do i bleed it or do i need to?
also, does anybody have little o-ring part number that sit inside smaller valve cover?
Old Nov 11, 2011 | 09:30 AM
NeedsWings's Avatar
Default Re: valve gasket - fuel line
yes you need to disconnect the fuel line there to remove the valve cover. the top panel on the valve cover is not an o-ring but rather mercedes sealant
Old Nov 11, 2011 | 09:43 AM
sleepydo's Avatar
do i need to bleed fuel line afterward? if so, how do i attempt that?
Old Nov 11, 2011 | 09:59 AM
NeedsWings's Avatar
nope, just crank the car, it will take an extra second or two to get the air out the line before the car fires. if you really want to bleed the line there is a shrader valve on the end of the fuel rail
syfi
Mar 28, 2026 04:14 PM
minimayhem
16
Aug 23, 2016 07:47 AM
JEFASOLD
Sep 28, 2015 12:10 PM
Billy22Bob
Sep 26, 2015 10:16 PM
RacerXofFL
Sep 15, 2015 05:00 PM
