Where is the body code plate located??
Old Jan 3, 2012 | 12:15 PM
wifes-05-xfire-conv's Avatar
Default Where is the body code plate located??
I am new to this forum, just bought a 2005 roadster limited and am looking for the body code plate or the identification plate that contains the paint code? I don not see it under the hood or the driver side door? This id driving me crazy!!!!
Thanks for any help!
Old Jan 3, 2012 | 12:37 PM
Default Re: Where is the body code plate located??
PAINT
SPECIFICATIONS - PAINT CODE
EXTERIOR COLORS
EXTERIOR COLOR DAIMLERCHRYSLER CODE
Sapphire Silver Metallic Clear Coat BS3
Graphite Metallic Clear Coat ZDR
Alabaster Clear Coat 960
Black Clear Coat 040
Blaze Red Crystal Pearl Coat ARH
INTERIOR COLORS
INTERIOR COLOR DAIMLERCHRYSLER CODE
Dark Slate Gray and Cedar two-tone XDV/ARK
Dark Slate Gray and Medium Slate Gray two-tone XDV/BD5
Dark Slate Gray monotone XDV
PAINT CODE
DESCRIPTION
Exterior vehicle body colors are identified on the Body Code plate. The plate is located on the in the engine compartment
and attached to the top of the right frame rail. Refer to the Introduction section at the front of this manual
for body code plate description. The first digit of the paint code listed on the vehicle indicates the sequence of
application, i.e.: P = primary coat, Q = secondary coat.
BASE COAT/CLEAR COAT FINISH
DESCRIPTION
The original equipment finish is a multi-step process that involves cleaning, electrodeposition (e-coat), base coat,
and clear coat steps. Additionally, selected areas of the vehicle may be coated with an anti-chip finish.
Old Jan 3, 2012 | 02:25 PM
Thanks for your quick reply!
I still can not find it, is the right frame rail the main support structure on the driver side?
I looked at both sides of the car under the hood and still don't see it, do you know what part it is close to?
These are normally an metal tag attached to the fire wall or frame aren't they.
Still Lost?
Old Jan 3, 2012 | 03:18 PM
Still Lost?
I can't find it either.
Old Jan 4, 2012 | 06:51 PM
kurtisberry's Avatar
Me neither. Certainly not where it is said to be. scratchpaint.com had a drawing showing where it is supposed to be, NOT.
Old Mar 24, 2013 | 12:03 PM
Lemon Twist's Avatar
Smile Re: Where is the body code plate located??
I looked all over as well. Expected the code to be on the door frame w the tire info. Nada.
Old Mar 25, 2013 | 05:52 PM
If we told you it would not be a secret anymore, sorry.
LOL
There isn't one on the car for some reason.
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 2, 2015 11:02 AM
WindRestrictor
Jul 29, 2015 03:58 PM
axnguyen
Jul 21, 2015 11:41 AM
syfi
Jul 12, 2015 05:59 PM
