Best Guess Leak
Old Jan 3, 2012 | 03:57 PM
Vegaslegal's Avatar
Default Best Guess Leak
By the smell, I've got an oil leak somewhere between the engine cover and the bottom plate. Nothing on floor so its minor, but after a long drive can even see a wisp of smoke. Definitely smells of oil. All fluids still up. Still under warranty, and will take it in later this week. What's the best guess of the problem, and time for repair?
Old Jan 3, 2012 | 04:01 PM
JHM2K's Avatar
Default Re: Best Guess Leak
Passenger side valve cover... I test-drove a car with exact same symptoms, and I pulled the airbox to see the same wisp of smoke coming from the upper valve cover. Common problem.
Old Jan 3, 2012 | 04:42 PM
The splash cover under the engine compartment prevents most engine leaks from apearing on the floor.
Old Jan 3, 2012 | 05:36 PM
Chris L.'s Avatar
Both of mine had the valve cover gasket leak.....appeared as thin film of oil on driver's side covers.
The 08 was under 3/36....free gasket repair. The 07 has a LPW & dealership said TSB to replace the valve covers entirely ....said it would have been >$1K.
minimayhem
16
Aug 23, 2016 07:47 AM
steps
Oct 13, 2015 06:18 PM
jimf
Oct 10, 2015 10:22 AM
Sep 28, 2015 07:40 PM
williammt
Sep 6, 2015 11:23 AM
