Air Intake Question
Old Feb 17, 2012 | 06:18 AM
burg1989's Avatar
Default Air Intake Question
I spent most of last night admiring peoples engines and how good there intake systems looked. I want to insert new pipes and air filters on the end, similar to the below pictures. I don't have a clue what Size pipes/Air filters i am going to need. Can someone please help? I would like to know the lenght and diameter of the pipes and would a 3" Filter on the ends work?
Just to add: I want to run the air filters closed to the front of the Grill to get cooler air, I know there is problems having them next to a boiling engine
Thanks
Old Feb 17, 2012 | 07:04 AM
Default Re: Air Intake Question
Thanks
It is generally agreed that a NeedsWings single CAI is appropriate for an N/A, however the dual ( DCAI ) looks much better ( and costs more too ).
The pipes are 3 ", I have a single NW CAI on my Roadster N/A, I run a K&N cone 3" neck x 6" x 3" filter just behind the grille.
One of the best looking ( and performing ) installations is the one by maxcichon - take a look at his gallery. He uses the enclosed inline filters.
Old Feb 17, 2012 | 07:16 AM
burg1989's Avatar
Thanks for the reply. Very useful.... Atleast now I have some idea on where to start!
I did take a look at maxcichon Car and it's very impressive! I do notice many users are also going for the Blingy look thesedays!
Old Feb 17, 2012 | 07:19 AM
Yep, Max is the King of Bling.
He's an artist with stainless steel - has a first rate shop at Auburn University he can use - lucky dog.......
Old Feb 17, 2012 | 10:40 AM
Russ59's Avatar
I'm considering doing this too, have done it to a few of my cars in the past.
but where is the stock air filter box which needs removing first??
Old Feb 17, 2012 | 10:50 AM
TomStratRT's Avatar
The engine cover houses the filters.
Old Feb 17, 2012 | 10:57 AM
Russ59's Avatar
[quote=TomStratRT]The engine cover houses the filters.[/quot
So does anything need removing apart from the original air filter elements, does the original air box stay put??
Old Feb 17, 2012 | 11:52 AM
The OEM engine cover/filters and the plastic tubes go on your wall as a trophy, you will have no engine cover with either of the NW CAI's, unless you can pick up one of the Mercedes covers like you will find here on the forum, I think onehundred80 listed some part numbers one time - search for it.
I am happy with leaving my engine naked.
Old Feb 17, 2012 | 01:22 PM
burg1989's Avatar
I am looking at replacing the exiting black pipes with Alloy ones either side, is 45 degrees a good option. I aim to have the air filters on the end of these
Old Feb 17, 2012 | 01:35 PM
maxcichon's Avatar
If the filters end up behind the radiator, you are NOT doing yourself any favors. This is classified as a "HOT Air Intake".
xfireohio
Jul 20, 2020 12:03 AM
Dnivek
Aug 7, 2015 07:18 AM
Buchacho
Aug 6, 2015 10:17 PM
itsky
Aug 4, 2015 10:35 PM
waldig
Jul 20, 2015 08:10 AM
