battery indicator help have trip soon!!!
Old Feb 20, 2012 | 11:55 AM
crossfire738's Avatar
Default battery indicator help have trip soon!!!
i have an 06 crossfire coupe 6 speed man. under hard acceleration the battery indicator light would come on and my lights would dim. this happened randomly on the highway too. i took it to the dealer for oil change and 23 point check. they checked my battery and said it was shot. they put in a new one for $139. not 50 feet out of the parking lot under hard acceleration it happened again..i have a 3 hour trip soon please help me resolve this!!! i have a 15 inch subwoofer installed but i dont run it very hard. i called the guys who did my sound system and said with the set up i have i should have zero problems from an old battery much less a new one??? help!!!
Old Feb 20, 2012 | 01:06 PM
amatxcrossfire's Avatar
Default Re: battery indicator help have trip soon!!!
I would say your alternater is going out, I replaced mine. I believe you
Can pick one up at autozone for a lot cheaper than a ome one
Old Feb 20, 2012 | 01:11 PM
MikeR's Avatar
It could be the voltage regulator on the back of the alternator that is going bad too.... it is replaceable also. You can have the alternator tested at a local parts shop....
Old Feb 20, 2012 | 01:12 PM
Kodebuster's Avatar
If they checked the battery for charging, I'm guessing it was just a voltage check under load, to make sure there was a minimum of greater than 13 or 14 volts being seen.
I would have them, or a local shop, or yourself, check the Alternator by pulling the fan belt, and spin it by hand for noise, or wobble.
If it's the Voltage Regulator, it's part of the Alternator.
Couldn't hurt to check the Codes via a Data Scanner, but I'd like to think the Dealer already did that...
Old Feb 20, 2012 | 01:22 PM
You could also pull the positive battery cable of while it is
Running an if it dies it would be the alternator
Old Feb 20, 2012 | 03:07 PM
The electronics on these cars love to see sparks ....... not.
I'd go with the alternator/regulator, grounds or cable connection.
Old Feb 20, 2012 | 03:35 PM
maxcichon's Avatar
Under hard accel?
How about a slipping belt? Bad tensioner?
Old Feb 20, 2012 | 04:43 PM
Mrmiata's Avatar
Sounds kinda familiar
Re: Mystery Issue... Generator/Alternator? - 12-07-2011 , 12:12 PM
Update,
This morning the charge/battery indicator lit immediately when the vehicle was started and stayed lit. So I guess it finally failed completely.
Going to pick up a new generator/alternator from O'Reilly Auto Parts in about 10 minutes. Will put it in this afternoon when the engine cools.
Will take pictures while changing it out and start a new thread.
https://www.crossfireforum.org/forum...lternator.html
Old Feb 20, 2012 | 04:45 PM
Talking Re: battery indicator help have trip soon!!!
thanks guys. most cars with really high dollar subs and amps have alternator trouble..thats probably what it is ill check and get back to yall thanks!!!!
Old Feb 21, 2012 | 07:06 AM
Angry Re: battery indicator help have trip soon!!!
KODEBUSTER, you might be right about the rattle. i havent pulled the belt yet but at idle the car runs horrible! it use to have a steady idle sound now it goes mmmm....mmmm....mmmm....mmmm....you get the picture..back to the dealership again today!!
Old Feb 22, 2012 | 02:25 PM
thanks guys..turned out to be the alt. all good now
Valk
Jul 12, 2021 09:49 PM
eikon
Sep 9, 2019 10:16 PM
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
81's
Sep 13, 2015 04:34 PM
