Help My Speedometer is bouncing!!!
Old May 13, 2012 | 12:33 AM
mhoward0058's Avatar
Default Help My Speedometer is bouncing!!!
When I let off the gas and coast, as i slow down the speedometer bounces around, it also tends to bounce a little bit while driving a steady speed as I go over bumps. Any Ideas about what it could be, I have an 04 automatic btw!! Thanks a bunch
Old May 13, 2012 | 07:46 AM
Default Re: Help My Speedometer is bouncing!!!
Manual says :
The speedometer receives wheel
speed data from the CAB via the CAN data bus and
can be verified by comparing the speed signal viewed
by the DRB IIIT from the wheel speed sensors and the
output seen on the Instrument Cluster.
CAB = Controller Antilock Brake
Sounds expensive $$$$
( but if it is effected by bouncing, could be a loose connection or maybe a loose wheel sensor ? )
pioneer4x4
Oct 6, 2018 01:09 AM
northwest_crossfire
May 30, 2016 05:19 PM
Infinite
Jun 28, 2010 04:33 PM
SRT6 Gang Member
Jun 11, 2008 10:03 AM
dyezak
Jan 5, 2008 10:08 AM
