Won't pass inspection because of my lights, any way to fix them?
4 Attachment(s)
went to my Chrysler dealer for an inspection and the guy told me that he couldn't pass it because of my headlights being "too fogged". He quoted me $180 because he said that he needs to take out both headlights and clean them from the inside (that's crazy!). So do you know anyway i can fix them without spending much money or buying new headlights?
Attachment 27153 Attachment 27154 Attachment 27155 Attachment 27156 |
Re: Won't pass inspection because of my lights, any way to fix them?
Looks like oxidation on the outside.
If do uou can sand and polish them. If that is not something you want to do yourself you can have a detail shop do it. |
Originally Posted by JoshnoSRT6
(Post 709134)
https://www.crossfireforum.org/forum...tml#post659138 https://www.crossfireforum.org/forum...tml#post638845 There are many posts on the exterior refinishing just use search. Outside refinishing will not cost more than $30 more like $20. |
Thank you! Will Definitely try it out! Thanks!
From the looks at the deposits, I have to wonder if the 'meth' will dissolve it cause it looks rather heavy not the foggy disposition I have seen on cars typically. Should soap and water was be attempted first to knock down some of that crud, Max??
Woody:confused: |
Best stuff I've used to clean the outside is a small kit made by 3M. It's a pad that attaches to the end of a drill, comes with various sanding pads and polishes. $20 at autozone, well worth it.
BTW, shame on you for letting your headlights look like that. |
From the looks of it, both inside and outside need some work. Do the headlights feel rough/sandy at the bottom? If not its on the inside. You can even get a kit by turtle wax from Walmart that works great.. even though the rest of their products are garbage. Do the outside and see if the ca will pass, if not just get it inspected at a gas station as they won't be as picky.
I'm curious if that crud in inside, or outside?
BTW, it is nearly impossible to clean the lenses from the inside, and you can only reach small areas to get condensation marks. I have poked a small wire with a cloth on the tip through the small bulb socket hole in the corner of the headlight assembly for very light cleaning. The clear plastic lens is glued on and is not made to come off. If for some reason there were more issues inside you would be better off getting another set, but that is very unlikely the issue.
Get the lens restore kits they work well, but it does take some time. Do not expect results with just 10 minutes work. |
indelibility has it right.
i used this kit and it was great. looked like brand-new. took 1/2 hour, maybe. |
Originally Posted by Toolman
(Post 709179)
I'd just focus on the outside right now. Tape the bumper off with blue painter's tape and get to work with one of the restoration kits. Otherwise, have a body shop professionally restore them for $100 or less. I doubt the inside is an issue or really even dirty at all.
"it's very feasible to separate the headlight by either using a heat gun or a stove on low heat, people do it all the time to paint the inner housing."
No kidding? Where have you seen that process? |
Originally Posted by Afterguard
(Post 709528)
No kidding? Where have you seen that process? At least I was correct in saying the oven method was no good, now I'm waiting for someone to prove me wrong on that as well.;) Live and learn. At $400 a pop I have no ambition to try it though. |
Originally Posted by waldig
(Post 709166)
Woody:confused: remove the assemblies and do a complete sand and polish. 3M or Meguiars kits. You might have to use a more aggressive wet/dry paper (than the P500 and P800 provided) to completely remove the damage from the surface. After they are polished on the outside, then see if the runny-looking film remains. That would require my tutorial on rinsing them out. I've only done that twice, but they both looked like the photos in the first post. Of course, that's JMHO, :rolleyes: |
Originally Posted by xman03
(Post 709258)
Do some reading, there is a DIY on here how to clean the inside with alcohol so you don't have to reach anywhere. Also it's very feasible to separate the headlight by either using a heat gun or a stove on low heat, people do it all the time to paint the inner housing.
Once again, I could be wrong. Anyone else?:confused: |
Max, I had tested that concept to destruction on a set of donor lamp housings. The urethane glue is not heat softened, you have to cut, pry and cut some more. The result is uneven and not worth the risk of damage unless you have donors and a injury wish. I had really different plans of storing equipment in the housing and decided it was too far uphill to actually do. BTW the lenses are glass and the internals are rather sophisticated for a light.
Enjoy, Woody |
(Post 709551)
Enjoy, Woody |
The internal Hemispherical projector lense, not the poly case front. Woody
Take your car to a different place for an inspection. He us just trying to make money off you. Not passing your car for that is rediculous.
| All times are GMT -4. The time now is 05:51 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
