Weight of stock rims?
Old Aug 26, 2004 | 10:11 PM
jas142's Avatar
Default Weight of stock rims?
Does anyone know the weight of the stocks 18s and 19s? Thanks
Old Aug 27, 2004 | 10:16 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Weight of stock rims?
i have an extra front rim in the box i can weigh....but no back rim...would this help?
Old Aug 27, 2004 | 11:55 PM
jas142's Avatar
Default
Sure, if you could weigh it I'd really appreciate it 8)
Old Aug 28, 2004 | 12:02 AM
VegasCrossfire's Avatar
Ok - I'll bite....why do you want to know???
Old Aug 28, 2004 | 12:10 AM
jsisabella's Avatar
Default
I have a stock 19" rim. I will weigh it tomorrow, just for fun!
Old Aug 28, 2004 | 12:30 AM
jas142's Avatar
Theoreticly, if they're heavy, they could be robbing alot of power. Rotational mass, (rims being a big source) hog power because the engine has to turn gigantic heavy 19" rims. Some light weight racing rims would not only look good, but might also help performance significantly.
Old Aug 28, 2004 | 01:23 AM
David Burns's Avatar
Default
I could swear someone posted the weight of the factory rims with the PS/2 tires mounted, he/she didn't want to unmount the tires to weigh the rims by themself. Should be able to get a weight from Michelin on the tires, and subtract, if we can find that post (it was MANY months ago).
Old Aug 28, 2004 | 10:03 AM
Dan Root's Avatar
Banned
Default
Since the SRT-6 has a lighter wheel for additional help in 0-60 speed. I would guess light wt. wheels would help slightly. But light wt. wheels bend and brake alot easier BEWARE. And they don't guarantee that. My guess stock wheels 17-19 lbs front, 19-22 rear. Light wt wheels are under 15 lbs. The SRTs are probably over that because of factory LIABILITY !!!
Old Aug 28, 2004 | 02:40 PM
Thank you for a rational, straight-forward answer. I appreciate that - and I learn new things all the time. Who knows, with all this knowledge, one of these days I might understand this stuff as much as the guys do .... yeagh sure. :wink:
Old Aug 28, 2004 | 11:12 PM
Cyril Baldwin's Avatar
Default
So, did anybody finally figured out the stock rims weight? Most of the rims I like weighs around 23 lbs. Any suggestions?
How about that SRT6 rims....they said they're from a Ferrari Modena?
Old Aug 29, 2004 | 12:35 AM
jas142's Avatar
Default
Anyone weigh them? lol still waiting
Old Aug 29, 2004 | 12:12 PM
jsisabella's Avatar
Default
OK, I weighed them:
The 19" rim w/ pressure sensor - 29 pounds
The 18" rim w/ pressure sensor and Dunlop Winter Sport M2 Snow Tire at 32 psi - 47 pounds
The small quantity of pressurized air has some weight, I am sure, but I think we can ignore it for these purposes!!!!!
Hope this helps for whatever reason you need it....
:lol:
Old Aug 29, 2004 | 12:45 PM
Dan Root's Avatar
Banned
Default
19" no tire right? Man that is a heavy wheel 7lbs over what I guessed. the front must over 22lbs also. time to look for new wheels.
Old Aug 29, 2004 | 12:52 PM
Dan Root's Avatar
Banned
Default
I priced HRE custom wheels they start around $800 a piece and weigh about 18-24 lbs.
Old Aug 29, 2004 | 12:56 PM
jsisabella's Avatar
Default
Correct
The 19" weight of 29 pounds is wheel only.
The 18" is wheel and snow tire combined at 47 pounds.
I don't have an unmounted 18" wheel to put on a scale.
Old Aug 29, 2004 | 01:09 PM
Dan Root's Avatar
Banned
Default
My guess would be 3-5 lbs lighter compared with rear weight. That would mean if a light weight wheel 19" or 18" about 18 lbs would improve 0-60 time, maybe as much as 1/3-1/2 sec. The reason i say that is from previous wheel and tire changes on my other cars that changed my own throttle feel from the line. That was the opposite though the car felt a little slower because of more overall weight increase. And wider tire.
Old Aug 29, 2004 | 01:10 PM
andrew's Avatar
Default
Originally Posted by jsisabella
OK, I weighed them:
i weighted my front rim: 25 lbs (no sensor...no tire)
Front Rim: 25 lbs
Rear Rim: 29 lbs
Old Aug 29, 2004 | 09:50 PM
Default
Originally Posted by andrew
Front Rim: 25 lbs
Rear Rim: 29 lbs
Good guess Dan. ops:
Old Aug 29, 2004 | 09:59 PM
Bullseye's Avatar
Default
Time to get those SSR racing rims 15lb for 17's Or go with some OZ superlegga's for 17's they are 15.4lbs and 18's are around 17. something. Talk about making a difference. Where are all the people that bashed me from bring this up a few weeks ago. I guess the TT's sparked speed interests :lol: Now time to put some gears in it what does it have stock for gearing?
Old Aug 29, 2004 | 10:11 PM
Default
Huh? I realize you've only been registered here a month, have you not had a chance to look back through old posts? You'll see we've been talking about improving the performance of this car for well over a year! LONG before the TT weenies had to blow into town and brag up their glorified beetle.
There's a thread called "Gears!". Check it out.
