BAS ESP
Old Sep 6, 2004 | 03:45 PM
Mouse Legend's Avatar
Default BAS ESP
Can anyone tell me if you have had this light come on?
BAS
ESP
I guess I will be taking a trip to the dealer tomorrow.
Any insight would be appreciated!
Old Sep 6, 2004 | 04:02 PM
SeaXfire's Avatar
Default
It is possible for the wheel positions sensor to lose calibration.
There is a procedure to fix it. It involves turning the wheel from left to right stop. It is in the owners manual so look it up and do it. Might save a trip to the shop.
Old Sep 6, 2004 | 04:06 PM
Default
Can't find it in the owner's manual. Can you give me a hint on where that would be?
pelked1's Avatar
Default
I removed my battery yesterday to clean it (here in the hot Arizona heat, they leak a little bit all of the time and need to be monitored frequently).
When I put it back in and drove off, My BAS ESP light was on as well. I drove about a 1/4 mile, made two regular turns, and it went off.
Old Sep 6, 2004 | 08:04 PM
Guest
Guest
Posts: n/a
Default
What does BAS ESP stand for?
Old Sep 6, 2004 | 08:06 PM
houstondan's Avatar
Default
try starting at page 132. on page 135 you'll find the procedure for resetting the system after a power interruption.
mine was on and the dealer wound-up replacing a module.
good luck
dan
Old Sep 6, 2004 | 11:39 PM
Default
Thanks! Went in the car and turned it one and moved the wheels to the left and then to the right and then drove it and the light never came on!
Thanks for the advice. I knew someone would be able to help me!
Old Sep 7, 2004 | 03:07 AM
saldous's Avatar
Default
It is covered in the manual. When I installed my illuminated door sills you have to remove the battery. After install and re-connecting battery this light came on. The manual says if the battery is disconnected this may happen and to do a full right lock then full left lock on the steering wheel to reset the sensor and the light goes off.
It is the Electronic Stability Program
northwest_crossfire
May 30, 2016 05:19 PM
xfClifford
27
Nov 10, 2015 10:08 PM
Reliableron
Oct 17, 2015 10:19 PM
velociabstract
15
Sep 7, 2015 03:43 PM
Blackout317
Jul 7, 2015 08:38 PM
