Shift knob problem
Old Sep 6, 2004 | 07:54 PM
ERCROSSFIRE04's Avatar
Default Shift **** problem
Has any one else experienced problems with their shift ****? I have the 6spd and every time i shift the **** has play as though its loose. i tried twisting it to see if it needed tightening but it wouldn't budge. any solutions?
Old Sep 6, 2004 | 08:03 PM
Default
Sorry guys i just did a search and found that i'm not the only one with this problem. i guess its time to visit the dealer before mine pops off.
Old Sep 7, 2004 | 09:10 AM
DFWSBR's Avatar
Default
It does not twist off, and you will only make the problem worse. Have a dealer inspect it. It is just a minor adjustment. There have been some situations where the shifter **** comes off while putting the car into reverse. A TSB calls for pulling up on the **** hard to see if it comes off. If it does, there are procedures for fixing it.
Old Sep 7, 2004 | 08:36 PM
AZ Outlaws's Avatar
Default
Do you have the TSB info? Nothing has been added to TSB forums... also there is at least one TSB there that hasn't been made a sticky.... thanks.
_____________________
'04 Coupe SSB 6-Speed #02815
Crossfire International (XFi)Charter Member
Lights on... Wings up... Let's go!!!
(It's A Hook-Up Thing)
"Left Coast Hook-Up" Survivor... May 15, 2004
"Malibu Canyon Hook-Up" Survivor... Jul 17, 2004
"Phoenix Ice Cream-Up" Survivor... Jul 31, 2004
"LV Aw Shucks-Up" Survivor... Aug 21, 2004
http://xfcars.forumflash.com
Old Sep 7, 2004 | 08:41 PM
DFWSBR's Avatar
Default
Well not really a TSB but more of a prep check.
Old Sep 7, 2004 | 10:33 PM
erbavor's Avatar
Default pop off
hey mine actually did pop right off. i was going for reverse, didnt pull any harder than normal, and it came right off. the **** the rubber sleeve and all. there was no warning though, no play prior to the incident. i put it back on and tried reverse again and again but nothing. i took it in and they replaced the whole packager anyway. just thought id let you know to have it checked while warranty applies.
Old Sep 8, 2004 | 08:30 PM
xf_newskool's Avatar
Default
mine popped off while on the test drive, and apparently there is a shift cable that they needed to replace (had to be ordered from germany, lol). anyway, its arrived, but now im waiting on a air pressure sensor to arrive before i make the trek to dealershipland
xf_newskool
Old Sep 10, 2004 | 10:08 AM
Default
Well just to add on, i just took mine in today and mine shifts fine. The only problem that i felt was weird was the **** itself feels like you can move it a small bit back and forth. they looked at it today and told me thats normal. the **** sits on a pivot ball and that allows the **** to move a small bit. is this true or should i take it back?
Old Sep 10, 2004 | 10:42 AM
saldous's Avatar
Default
Mine is an auto gearbox and mine doesn't move at all. As for how it attaches see below:
Old Sep 10, 2004 | 10:50 AM
Default
so when i'm shifting, the **** moves slightly back and forth. not to much but enough to where it has a feeling like its loose? are these ***** twisted on? held by a retainer...manual shift ***** by the way. i know a normal **** is screwed on and i have tried twisting this one and no response as though it wants to tighten up.
Old Oct 28, 2004 | 11:19 AM
Default Re: Shift **** problem
any more info on this guys. i dont think i'm the only one with this problem out there. my shift **** is still a bit loose. any one take theres in? if so...what did the dealership say, did they fix it? looking for info .....
rdougc
Sep 5, 2015 10:30 PM
Crossfireone
23
Aug 25, 2015 04:56 AM
Cuda56
Aug 11, 2015 12:11 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
