It won't start. It blows a fuse all the time
Old Apr 21, 2013 | 08:57 PM
vallejoricky's Avatar
Default It won't start. It blows a fuse all the time
Hello,
I have a very unusual problem. I have attached a picture to show a fuse that keeps going off. The car cranks when starting but that's it. I changed the CPS already and nothing seems to happen. I was wondering if somebody knows what the problem might be. I also had a spare key that I got made by a locksmith and try using it for a couple of times. The car started but would shut off right away. I used the original key again and worked like a charm for one day. Next day I get up to go to work and the Crossfire didn't start anymore. Before that the car wanted to shut down couple of times at light stops. I took it to Autozone and the codes were relay failure or Air pump. 801 code I believe. I would love to start the car and drive it to take it to the mechanic to fix the 801 code.
Old Apr 22, 2013 | 10:38 AM
KoKaneFire's Avatar
Default Re: It won't start. It blows a fuse all the time
What fuse is that for?
Old Apr 22, 2013 | 10:54 AM
MX5racer's Avatar
Maybe check all your relays, can be easily done with a multi volt meter
Old Apr 22, 2013 | 10:58 AM
Originally Posted by vallejoricky
Hello,
I think it's the fuel pump relay.
Old Apr 23, 2013 | 11:50 AM
I think I am going to do the RCM soldering because it seems that its beat up. Do you think that might be the problem?
Old Apr 23, 2013 | 08:57 PM
That is what I am trying to figure out. Some people say that it might also be the anti-theft system. How would I find out if that is the case or not? I fixed the RCM soldering but I do not want to fix a relay if that is not a problem.
Old Apr 23, 2013 | 09:03 PM
When you turn the ignition on to the position before the engine turns over can you hear the fuel pump?
The fuse is for the fuel pump I think.
Old Apr 23, 2013 | 09:15 PM
Well I believe it does, the car powers on for 1 or 2 seconds when I put a new fuse then it shuts down and blows the fuse. After that it just cranks.
Old Apr 23, 2013 | 10:28 PM
Mrmiata's Avatar
I agree with 180 .. already... LOL
oldvintagedude
Aug 14, 2015 06:20 AM
BrenLW
Aug 5, 2015 04:53 AM
BrenLW
Aug 4, 2015 01:29 PM
cx24724
Jul 12, 2015 11:57 AM
bdh
Jul 9, 2015 09:40 AM
