Rear Tire Air loss
Old Sep 10, 2004 | 05:24 PM
jp's Avatar
jp
Default Rear Tire Air loss
I have been experiencing since new a loss of 6 pounds of pressure per day on my left rear tire. There is no hole or puncture. The tires are the Conti all season tires. Any suggestions? Thanks.
Old Sep 10, 2004 | 06:13 PM
oldfritz's Avatar
Default
Not to give you a short reply, but I would suggest taking the vehicle back to the dealer and explaining that you are losing six pounds per day in the left rear tire....
Fritz
Old Sep 10, 2004 | 08:16 PM
bazyar's Avatar
Default
Your wheel might have a crack in it allowing the air to escape. 6 psi a day is abnormal. Take it back to the dealer and have them inspect the rim or try a new tire on it to see if you have a bad tire installed. Also, it could be the bead seal is no good, which would cause the air to leak. But that would be more dramatic.
Good Luck!!
Old Sep 10, 2004 | 08:26 PM
Guest
Guest
Posts: n/a
Default
That happened to us on one of the race cars, turned out to to be a loose valve stem. But the cracked wheel sounds like another logical problem.
Old Sep 11, 2004 | 05:43 PM
xf_newskool's Avatar
Default
if your xf is equipped with air pressure sensors, they are a bolt in style, and might not be torqued properly (causing a air loss). just my 2c....
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Jul 28, 2015 08:12 AM
cjfine
Jul 20, 2015 11:58 PM
waldig
Jul 20, 2015 08:10 AM
Buchacho
Jul 9, 2015 04:13 PM
