Old Sep 10, 2004 | 08:16 PM
bazyar's Avatar
bazyar
Default
Your wheel might have a crack in it allowing the air to escape. 6 psi a day is abnormal. Take it back to the dealer and have them inspect the rim or try a new tire on it to see if you have a bad tire installed. Also, it could be the bead seal is no good, which would cause the air to leak. But that would be more dramatic.
Good Luck!!
