Rim size? question
Old Feb 28, 2014 | 05:39 PM
andrew96's Avatar
Default Rim size? question
I am looking to put aftermarket rims on the stock tire size.
For the fronts, will the aftermarket rim size 18x8.5 fit the stock tires?
And for the rear, will the aftermarket rim size 19x10 fit the rear stock tires?
Thanks
Old Feb 28, 2014 | 06:00 PM
caseycowan5's Avatar
Default Re: Rim size? question
yes if you have somewhere to stretch your tires and want stretched tires. Check this site out.
http://tyrestretch.com/
Old Mar 1, 2014 | 12:42 AM
JEFASOLD's Avatar
Thanks
Yes, they will. They are not optimum and you need to make sure to have the offsets be appropriate to avoid any rubbing issues.
Old Mar 1, 2014 | 10:34 AM
andrew96's Avatar
the front have an offset of 35, and rear is 25, which i think those are both the very close, if not the same to the stock off sit, so they should be fine
Old Mar 4, 2014 | 10:23 AM
sozine12's Avatar
Default How to checking the rim size?
we have M/Benz trucks we want checking the rim size i dont how to checking the rim size
BrenLW
Aug 5, 2015 04:53 AM
onehundred80
Aug 2, 2015 11:37 AM
onehundred80
Canada
Jul 24, 2015 03:50 PM
crymar
Jul 17, 2015 08:46 AM
syfi
Jul 12, 2015 05:59 PM
