Heated seats
Old Dec 14, 2004 | 09:50 PM
xfirejunky's Avatar
Default Heated seats
Anyone from the cooler climates tried the heated seats yet? I want to know what gets warm, the Lumbar area (lower back) or the seat area (rump). I tried mine for the first time and my but stayed cold. Trying to see if this is normal operation. Thanx
Old Dec 14, 2004 | 10:55 PM
John Webster's Avatar
Default Re: Heated seats
Just the backs heat up on mine.
There's also no heat in the footwell unless you close off all the dash vents. That sucks and there should be a fix for it but the dealer says that's just the way the car is.
Old Dec 14, 2004 | 11:29 PM
oldfritz's Avatar
Doesn't get very cold here very often, but right now it's a bit chilly in the Atlanta area (for us southerners, that is) and I've used the heated seats the past couple of days just to see if they worked, and I was impressed. Both the bottom and the back of the driver's seat got warm very quickly. As a matter of fact, I had to put the switch on the low position in a matter of minutes. However, I'm glad to get the info regarding the floor heat, I couldn't figure that one out at all.
Old Dec 15, 2004 | 03:51 AM
r.robertson's Avatar
Use heated seats all the time. (scotland is freezing) Heat is on the mid and lower back plus the ***.
They work great and would never buy a new car without them.
Old Dec 15, 2004 | 04:35 AM
ambcarlson's Avatar
I love my heated seats. I live way up in Upper Michigan and I like to ride with the windows down and the seats on. Mine take a while to heat up, but it is the back and the butt and once they do heat up, I have to turn them to low. The heated side mirrors also work great too!
Old Dec 15, 2004 | 07:11 AM
Scottish XF's Avatar
Found the heated seats get warm quickly (within 2 minutes of starting the car and certainly before the heater starts to blow hot) which is the only good thing about starting a 6:30am commute!
Make sure you select the second setting (two lights) and you should notice it heating your backside as well.
Old Dec 15, 2004 | 08:45 AM
xfirejunky's Avatar
Thanks for everybodies input. It appears the consensus is that my butt should also be getting warm. Well another trip to the dealer.
Old Dec 15, 2004 | 09:05 AM
NJspeed69's Avatar
Yeah your butt should get warm. They work great. It's 25 degrees here this morning in New Jersey so I definately use them!
I find it wierd that when you turn it on at first, theres 2 lights lit up. After a while I guess they get hot and then it goes to 1 light. I assume that happens to everyone too? Sometimes its annoying because I'm cold and I wish it would just stay on 2 until I change it to 1 myself.
Old Dec 15, 2004 | 09:15 AM
Gunner's Avatar
The back and the seat get very hot in mine, then it defaults to the low setting (one red light,vice two). They are great! Was 27 when I left for work this morning.
Old Dec 15, 2004 | 09:17 AM
Gunner's Avatar
Just push the buton again, they will both come on and it will heat up to the max temp.
Old Dec 15, 2004 | 01:18 PM
toolroom's Avatar
xfirejunky, Let me know what the dealer finds out. I just tried mine and both seat and back on passenger seat heat, but only the back on drivers seat. Something unplugged maybe?
Old Dec 15, 2004 | 02:31 PM
xfirejunky's Avatar
I have an appointment Tues with the dealer to gete an oil change and check my seats. I'll let everyone know what happened next Tues or Wed.
Old Dec 15, 2004 | 04:21 PM
GoodEnough's Avatar
I agree, not having the floor setting is a bummer. I close the upper vents & only get the heat to the floor too. It seems they could have done away with one of the other settings to get a floor only.
I use the heated seats everytime I get into the car. It just feels good. In Southern California it's supposed to be mid to upper 70's today, I will still turn them on to soothe the muscles. Every car I will buy will have them.
Old Dec 17, 2004 | 11:20 AM
scotth_uk's Avatar
I use mine every day at the moment, however the heat stretches the leather. At 7200 miles my drivers seat looks really bad in comparison to the passenger seat which is rarely used.
Old Dec 17, 2004 | 01:50 PM
Galen Dracos's Avatar
I've got a cold butt version too. I know it worked fine last winter. I was just wondering if I was getting old-timers disease or if something broke (glad someone else posted this already, that what I was comming in to check on). And, I'm just too lazy to sit on the Pass side long enough to try it there (if I'm in it, I'm behind the wheel ). Will have to make sure that one is working now.
Thanks!
Old Dec 18, 2004 | 11:31 PM
themann42's Avatar
i use the heated seats ALL the time. i love them. i find most the heat pretty evenly more distributed, but prolly a little warmer on the bottom part
Valk
Jul 12, 2021 09:49 PM
steps
Apr 26, 2016 06:21 PM
atdavis2
Sep 21, 2015 01:25 PM
steps
Sep 19, 2015 10:43 PM
westonrose
U.K.
Sep 16, 2015 02:22 PM
