Best wheel spacers for stock rims?
Old Feb 14, 2015 | 12:05 PM
kragath's Avatar
Cool Best wheel spacers for stock rims?
So Im planning to widen my basic coupe 05's stance. It's lowered 30mm with Eibachs springs...
I would check how much there is space to widen but my car is sitting in garage about 100km from where I live.
So if someone has already experienced what I'm about to do I would appreciate some hint.
10mm front? 20mm rear? I don't want wide too much but just to make it look better.
Old Feb 23, 2015 | 11:56 AM
xxx_fire's Avatar
Default Re: Best wheel spacers for stock rims?
I have 25mm spacers in the rear and 10mm in the front. I'm using H&R... Whatever you get you have to make sure Thier hub centric ��
Old Mar 2, 2015 | 11:43 AM
kragath's Avatar
Thumbs up Re: Best wheel spacers for stock rims?
xxx_fire have you lowered your x-fire's stance also?
Yeah I read that hub centric are better. Worth of some extra money also from what i've heard.
I just looked from the Ebay and found some Eibachs pro spacers kit.
Thanks for the info!
Old Mar 2, 2015 | 06:23 PM
whoosh's Avatar
eibach and h&r for best brands and don't forget to get longer bolts.
Old Mar 9, 2015 | 05:33 PM
Trenzman's Avatar
Eibach comes with the longer lugs already.
Old Mar 9, 2015 | 07:57 PM
Remember to lengthen lug bolts to the same mm you use on the spacer. I have done 15mm all around on the coupe and used 15 mm longer bolts. And as mentioned, use hub centric spacers only.
tom2112
Dec 1, 2015 09:02 AM
gblack32
Sep 30, 2015 01:13 AM
velociabstract
Aug 7, 2015 01:30 PM
tom2112
Jul 28, 2015 08:12 AM
Buchacho
Jul 9, 2015 04:13 PM
